Output Volume is LOW?
Hey guys,
I was experimenting with reamping a DI'd gutiar signal last nite and sorta ran into a couple problems. First off I would have to eliminate the master fader in order to keep from routing all the tracks through the output that i assigned for the track i wanted outputed. In the process of figuring how to send "only" the desired track out, i got some feedback. Everything seemed alright until outputed all my tracks back to 1/2 for playback, now my overall volume is almost half of what it was before i started. I even tried starting another session and it's the same problem, "low volume". Is there a chance I did something to the interface, or am i missing something hear? My monitors are cheap M-Audio DX4's, Could i of blown my monitors? I'm using a MBOX PRO interface/W a..MAC BOOK PRO... Thanks |
Re: Output Volume is LOW?
You could try trashing preferences, which will 'reset' everything - maybe that will clear up the issue. Did anything change with the Mix or Monitor knobs on the front of the Mbox 2 Pro during this process? Any change there could affect output volume. |
Output Volume | The Guitar Man | General Discussion | 1 | 09-05-2012 07:17 PM |
Can't adjust volume of OS X, only the output volume of ER | JustGoWithIt | Eleven Rack | 8 | 09-26-2011 01:32 PM |
output volume changes by itself | singtall | Eleven Rack | 6 | 04-23-2011 08:24 PM |
How to increase output volume | higginsdj | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 05-07-2010 09:38 PM |
Low Output volume in LE | Kluson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 11-28-2008 02:20 PM |
