Edit Window Display not completely visible
This is my first time posting a topic! I am a new user [2 weeks]and still have version 5.0.1 software. I plan on upgrading to the latest version of software ASAP.
Here's my problem. No matter how I try, I am unable to access the pop-up menu button on the grid box at the upper right hand side of the edit window, because it isn't visible! As I look closely, it appears that the Edit Window has been truncated so that the end of the box is no longer visible. I have tried to no avail to enlarge the view. Has anyone had this problem? Any suggestions?
Check out my band ALTER at www.mp3.com/alter |
Re: Edit Window Display not completely visible
Hi Douglas,
I used to have a 15" monitor, and had the same problem. You have a couple of choices... One, you can change your screen resolution to make everything fit within the monitor. On your desktop, right click, choose 'Properties/Settings', and set it to 1024x768.(It may be at 800x600 now). Hit 'Apply' and reboot. Now, this will make everything smaller overall, so if you want to keep the same resolution as before, just for the sake of size, you can do this. These keystrokes will change your Grid Note and Nudge Note settings... To change Grid Note: Alt/Ctl. and + or - To change Nudge Note: Alt/Start and + or - I use these keystrokes regardless, because they're quicker, to me. Post back anytime if you have any questions, and I hope this helps... [img]images/icons/wink.gif[/img] ~Roy
rh music |
Thanks, Roy. You've solved my problem. You also put a big smile on my face.
Cheers, Greg
External Display for Mix/Edit window | rakprachow | Windows | 2 | 10-26-2011 09:34 PM |
Edit Window Display problem... | Benjamino | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-09-2010 11:03 AM |
Please help Digi Support! Automation Control Window doesn't display completely | marisolmet | Pro Tools M-Powered (Mac) | 2 | 09-14-2008 07:16 AM |
Midi edit window display ? | Eddie K. wannabe | MIDI | 0 | 05-03-2003 07:58 PM |
problem with edit window display | spencer_davey | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-04-2002 08:11 PM |
