i7 CPU, SSD HD, fast record drive - & still get crunching noise at 128 samples. Help!
I'm at my wit's end here. I cannot use the 128 samples H/W Buffer size without a horrible, daleks style crunching distortion effect. I also get it sometimes at 256 samples. Initially I thought it was because I was recording to the same drive as Pro Tools was on.. so got an external, 7200rpm USB 3.0 record drive. The problem remained. So now I've swapped the slow, old 5400rpm internal drive for a Samsung 830 256mb SSD drive, and reinstalled windows 7 and Pro Tools 9 MP. The problem remained. I have done every possible optimization as recommended by Avid. The problem remains! The only thing I have not been able to do, is switch off the "Intel Turbo Boost" feature of this laptop (which is recommended by Avid), as I cannot find the option in the BIOS as Avid suggests. Could this be the cause of this issue all along? Sandra report below.. SiSoftware Sandra Computer Model : Dell Dell System Inspiron N7110 Workgroup : WORKGROUP Host Name : G-Unit User : George Processor Model : Intel(R) Core(TM) i7-2670QM CPU @ 2.20GHz Speed : 2.2GHz Cores per Processor : 4 Unit(s) Threads per Core : 2 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 On-board Cache : 4x 256kB, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 On-board Cache : 6MB, Synchronous, ATC, 12-way, Exclusive, 64 byte line size, 8 threads sharing Computer Mainboard : Dell 0RP6C8 BIOS : Dell A13 09/05/2012 Bus(es) : X-Bus PCI PCIe USB Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : No Total Memory : 3.9GB Chipset Model : Dell 0104h Front Side Bus Speed : 1x 100MHz (100MHz) Video System Video Adapter : Intel(R) HD Graphics Family (SM5.0, 1GB, PCI) Graphics Processor Adapter : NVIDIA GeForce GT 525M (16SP 2C 1.2GHz, 1023.8MB) Adapter : NVIDIA GeForce GT 525M (16SP 2C 1.2GHz, 1023.8MB) Adapter : Intel(R) HD Graphics Family (978.6MB) Adapter : NVIDIA GeForce GT 525M (978.6MB) Storage Devices SAMSUNG SSD 830 Series 256GB (SATA600, SSD, NCQ) : 238GB (C:) WDC WD5000AAKS-00UU3A0 (500.1GB, USB/SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) : 466GB (F:) TSSTcorp DVD+/-RW SN-208BB (SATA150, DVD+-RW, CD-RW, 1MB Cache) : N/A (D:) Disk : N/A (E:) Logical Storage Devices RECOVERY : 20GB (NTFS) Work (F:) : 466GB (NTFS) @ WDC WD5000AAKS-00UU3A0 (500.1GB, USB/SATA300, 3.5", 7200rpm, NCQ, 16MB Cache) OS (C:) : 219GB (NTFS) @ SAMSUNG SSD 830 Series 256GB (SATA600, SSD, NCQ) Optical Drive (D:) : N/A @ TSSTcorp DVD+/-RW SN-208BB (SATA150, DVD+-RW, CD-RW, 1MB Cache) Optical Drive (E:) : N/A @ Disk Peripherals LPC Hub Controller 1 : Dell 1C4Bh LPC Legacy Controller 1 : Winbond W83687THF Audio Device : Dell 1C20h Audio Codec : Realtek Semiconductor High Definition Audio Disk Controller : Dell 1C03h USB Controller 1 : Dell 1C2Dh USB Controller 2 : Dell 1C26h Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Network Services Network Adapter : Realtek PCIe FE Family Controller Network Adapter : Bluetooth Device (Personal Area Network) Wireless Adapter 1 : Intel(R) Centrino(R) Wireless-N 1030 (802.11g (ERP), AES-CCMP, 144Mbps) Power Management Mains (AC) Line Status : On-Line Battery No 1 : 100% Operating System Windows System : Microsoft Windows 7 Home 6.01.7601 (Service Pack 1) Platform Compliance : x64 Windows Experience Index Current System : 4.6 |
What interface are you using? Sounds more like a driver issue than a computer issue. But on all honesty I barely even scanned your Sandra report. Maybe there it something incompatible. Someone else would know much better. :)
Dell T5810. Harrison Mixbus 32C. Haven't used PT since 2015 and never been happier. |
Re: i7 CPU, SSD HD, fast record drive - & still get crunching noise at 128 samples. H
Is this with your MobilePre or Profire 2626 ? If you have a look back at my latest posts I've had similar issues.
IRQ conflicts. |
It's definitely not the hard drives, and I'm pretty sure it's not the interface. So what about this "Intel Turbo Boost?" Anyone know? thanks |
This is with the MobilePre, but as I said it happened with my old mbox 1 too. What is an IRQ conflict? Is it like certain devices conflicting with each other? If so, how do I ascertain which ones are conflicting? I will check out your posts. cheers |
IRQ conflicts - bad news really.
Have a look in the Device Manager, conflicts show as yellow exclamation marks. Check those out and you'll find a resource is shared. My previous posts suggest that I have HP DV6 i7 720QM laptop working fine - well an issue has come into play. Crackling, distorted audio. Can't turn off anything in the BIOS. My only thought is to install another drive, do a fresh Win 7 install and then not install any drivers not essential for a barebones Pro Tools build - things like the bluetooth, wi-fi as I can't disable them in the BIOS. Things always change mind and in the meantime I have a 3570k, B75 chipset build to bench, so the DV6 is on the back burner for now Last edited by Transputer; 11-22-2012 at 03:26 AM. Reason: exclamation marks |
I'm wondering if the problem I'm having lies with the fact the MobilePre refuses to work on USB 3.0 ports.. maybe as it's using USB 2.0 it is causing a bottleneck? I think I've got the most up to date driver, but Avid seems to have stopped supporting M-Audio products and my driver dates back to 2009 I think. |
That's exactly what's happening to mine Georgerob. Mine clears up when switching to 256 sample rate. Wierd thing is it works fine on my Intel Core 2 Duo rig. Unfortunately I can't record very many tracks with it. It seems to be some processor function that is causing this to me.
Intel Core i5 MSI Z77MA G-45 Motherboard 8gb DDR3 Corsair Vengeance Several Sata Hdds XFX 9500gt |
Pro Tools 9MP on SSD ok? Then Fast SATA for Record drive? | Georgerob | Windows | 6 | 10-24-2012 03:28 AM |
"DAE can't get audio from drive fast enough. Drive may be too slow or fragmented, or | iminzayne | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 16 | 04-15-2010 10:28 PM |
how can I get a bit crunching effect in protools? | technician | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 10-09-2003 11:12 AM |
Crunching no clipping | lcouri | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-08-2001 11:06 AM |
Fast panning produces noise like a noisy pan pot! Is this "Zipper noise?" | Jules | Pro Tools TDM Systems (Mac) | 4 | 03-02-2000 03:12 AM |
