Old 12-31-2015, 12:26 AM
davemartone's Avatar
davemartone davemartone is offline
Default ONE SSD for ALL
Searching for weeks for this answer and there is no real answer I can find.
Old days we had
OS one drive
Audio one drive
Samples one drive
Today.. SSD 1 TB eg.
Run OS/Samples and Audio writing reading.
External for Backup.
Partitioned? No yes?
Not looking for thoughts, but actual proof.
Makes sense in 2016 to put it all on one drive. Back it up. and enjoy the speed.
I know most projects will be stored in Ram as well.
Thanks in advance.
Old 12-31-2015, 12:46 AM
abre abre is offline
Default Re: ONE SSD for ALL
I am doing just that. Everything on one SSD. Backup on external drive.
Old 12-31-2015, 01:15 AM
mhuang mhuang is offline
personally, I still go with 2 SSDs minimum, 1 for OS and 1 for project drive.
I rather spread out the write life cycle to 2 SSD instead of 1.
Old 12-31-2015, 01:22 AM
At this point in the game, life of the SSD does not really seem relevant.
Check this out
http://www.pcworld.com/article/28560...ity-fears.html
Old 12-31-2015, 05:20 AM
thewiz's Avatar
thewiz thewiz is offline
Same here I work on the 500gig SSD internal drive on both my Mac.. huge thunderbolt Raid HD for backup only..
Old 12-31-2015, 05:36 AM
7Seas's Avatar
7Seas 7Seas is offline
OS should in principle always be in a separate drive.
The question is not so much speed (although speed is always a consideration), with SSDs and all, but with the fact that you would be putting everything through the same I/O path and therefore potentiating a 'Single Point of Failure' event.
Z.
Old 12-31-2015, 05:45 AM
I say put everything on the SSD. Except the backup. Get your monies worth
Old 12-31-2015, 06:21 AM
grayter1 grayter1 is offline
I'm still old school -
1 SSD for the OS and programs
1 SSD for samples
1 big 2 TB spinning disk for audio & video scratch.
I'm beginning to re-think the spinning drive, and may want to replace it with a 1 TB SSD.
Anyone still using platter drives?
tg
Mac Studio (2022) M1 MAX / 64GB / 2TB HD / macOS Ventura 13.6.5 / RME BabyFace Pro FS / SSL UF8 + UF1 + UC1 / Roland SYSTEM 8 / Kontrol S61 mk3 / Pro Tools Studio 2024.3 / Nuendo 13 / Reaper 7 / Komplete 14 / Omnisphere / Keyscape / Trilian / V Collection X
Old 12-31-2015, 06:33 AM
Craig F Craig F is offline
on a Desktop machine I still recommend separate drives for each
on a Laptop OS/Samples on one, sessions on another
everything on 1 drive still makes me nervous and makes drive/data management a PITA
Thank you,
Craig
Old 12-31-2015, 06:44 AM
littlesicily littlesicily is offline
Mac Pro w/ 4 internal Drive bays...
1 SSD for OS
1 SSD for Audio
1 SSD for Samples
1 spinning HD for other Media (itunes, iphoto)
Backups of each w/ spinning HDs.
