What's the best way to increase the volume?
Hi Friends...
After spending months mixing a song, I've found that many of my tracks are far below 0db. Most vocal tracks are 0db, but most of the instrumentation ended up between -6 and -15db. As a result, the final output is not quite as strong and punchy as could be. My question: 1) Is it best/easiest to simply raise the master fader from 0 to 5db? 2) Or is it better to leave the master fader at 0db and raise each individual track by 5db? Or does that not matter? If the latter, what the easiest way of raising ALL tracks by 5db so I can preserve all the automation? Create a group of everything? |
Re: What's the best way to increase the volume?
If your master is nowhere near clipping, then just raise the fader.
Sent from my iPhone using Tapatalk |
With digital audio, it's just math. So, increasing track levels or raising the master fader (or lowering if it's clipping) should produce the same result, no loss of quality. The simple way to fix this situation; put a limiter last on your master fader, set it to limit at -0.5db, and raise the master fader so that the limiter only just limits a tiny bit once in a while. Remember, unlike all other types of tracks, master fader plugins is after the fader.
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
Don't get hung up on reaching 0db. In fact, you don't want to get close to 0db. Why do you feel you need to do anything? Consider:
1-maxing out the meters is a holdover from the analog days where it was important to maximize signal to noise(noise being tape noise). In the digital realm, tape noise doesn't exist(unless you are transferring old tapes). 2-proper levels in digital are generally -18 to -14db. IOW, just reaching yellow on the meters is fine for recording. 3-if you are looking at the master, sure its fine to push closer to 0, but(and this is a bit BUT), A-is the project going to be mastered?(if yes, let the ME push the level to the desired volume for the final product, be it CD replication or an on-line service such as CD Baby or Spotify). Or B-if you are self mastering(something I discourage unless you are highly experienced), then the final level is part of that mastering process, and many mastering plugins are equipped to handle this(but again, this is a Master track process, not something that needs consideration on individual tracks). 4-having said all of the above, I am highly experienced, but still hate to do my own mastering. And I almost always end up lowering all my audio tracks to maintain a clean mix 2 more cents worth, and my opinion only; if most of your tracks had the faders at -10 and lower, then I would say you need to bring down levels on the tracks(look at what plugins are in use and make sure any/all are not making your tracks significantly louder than if they were bypassed). Your screen shot doesn't look like this, so your faders look in a good range to me
Dave, his question was quite simple and to the point:
I think your reply was a little too much, with all respect. I know you're being helpful, just sayin'.
I too answered the question - in ONE line. Sent from my iPhone using Tapatalk |
I personally benefited from both slants on this.
Thanks guys!
A rough sea makes a smooth sailor. Pro Tools Studio 2022.7|Windows 10 22H2|Focusrite Scarlett 2i2 (2nd Gen)|Dell Inspiron 3650|Intel i5 6th gen|16GB RAM|Samsung T5 SSD's|Hitachi|Touro HDD Toontrack EZdrummer 3|Steven Slate Drums 5.5 + Blackbird Studio EX|Spectrasonics Trilian|Native Instruments Guitar Rig 6 Waves|SSL Native|Fabfilter|Softube|Soundtoys|Nomad Factory |
I can tell you this, Dave’s response gave me a heck of a lot more to think about rather than a simple one line answer. I think it’s missing in these types of responses in most online forums is perspective.
Sure. But the question asked was a simple one. Do I need to turn all channels up or can I just increase the master fader? The answer is also simple. If it’s not clipping, turn the master up. Sent from my iPhone using Tapatalk |
We should applaud people for trying to go further in helping others, not chastise them. |
How to increase output volume | higginsdj | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 05-07-2010 09:38 PM |
Increase Volume on microphone | AirJordan1 | Pro Tools M-Powered (Win) | 4 | 10-08-2009 01:21 PM |
How to use maximiser to increase volume of mix? | johannh | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 01-08-2007 07:20 PM |
How to use maximiser to increase volume of mix? | johannh | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-07-2007 07:33 PM |
Increase volume after track recorded | jsampedro | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 01-22-2003 08:30 PM |
