![]() I'm running ProTools LE version 6 (free) on my new Powerbook G4 (15") and whenever I go to try and record something, the Workspace window pops up and I get the following error whenever I try and hit the 'R': "Macintosh HD cannot be designated as an Audio Record volume because it is not a valid audio volume" I get the same result when I try and designate my external firewire drive (Maxtor 38GB). Yet when I start up in OS9, I can run and record things in Protools LE, no problems. Any ideas? Thanks in advance! |
I am not using the free version.
But if I unload ProTools with the script somebody here wrote, then the drives are turned into not recordable. Here's what I do. Reboot. Start ProTools DON't open a session. Open the worspace browser window (I can't remember the exact name) Change the drives to 'R' See if that works. Mark
Mark Hollingsworth |
Where did you get a "free" version 6 of PT? I thought there was only a free version of 5.0 that only runs under OS9.
http://www.digidesign.com/download/ In any case, ALL of your record volumes MUST be reformatted using the OSX disc utility as HFS+ before using PT6 with OSX (even if they were previously formatted as such under OS9). NOTE: Reformatting will erase all of the data on a volume. http://duc.digidesign.com/showflat.p...=5&o=7&fpart=1 dk
www.dpksound.com |
Pro Tools error message "Session must be an audio record volume" | DeejayMaurice | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 09-10-2011 06:42 AM |
Problem 7.4 Upgrade Error Message - Record Volume | akakpaws | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-06-2007 08:45 PM |
Audio Record Volume Message | emelare | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-05-2006 11:20 AM |
I'm Getting A "Audio Record Volume" Error Message | MITCHELLBOY | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-15-2005 06:20 AM |
"Audio Record Volume" message????? | billthegrill | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 09-16-2004 05:45 PM |
