Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 10-20-2009, 08:30 AM
mediapimp mediapimp is offline
Default Select area of audio in between markers
I am trying to figure out how to make a selection in a region using markers.
I have placed 2 markers, one at the beginning of the area I want to select and one at the end.
I know that if I click just to the left of the first marker in the Markers lane and then press tab, the playhead jumps to the first marker.
If I then press Shift+Tab, the area in between the 2 markers gets selected but only in the Markers lane.
I need the selection to be in regions area.
Any help is appreciated.
Old 10-20-2009, 09:06 AM
Eric Seaberg's Avatar
Eric Seaberg Eric Seaberg is offline
Default Re: Select area of audio in between markers
Open the MEMORY LOCATIONS window. Select the tracks you want on the left of the edit window where the record, input, etc. buttons are. Hit MARKER 1 in the MEMORY LOCATIONS window, hold down SHIFT and hit MARKER 2.
Eric Seaberg • San Diego, CA
A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S.
Old 10-20-2009, 09:10 AM
Perfect!
Thank you!!!
Can't select an area in a single track luccascorrea Pro Tools M-Powered (Mac) 6 04-07-2023 12:01 AM
Beat Markers Appearing As Elastic Audio Markers Fabdickson Pro Tools 9 1 03-06-2012 05:03 PM
Can't select audio between markers bwillman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-25-2008 08:38 PM
Import Audio dialog , Can't select or play audio Irl Sanders Pro Tools TDM Systems (Mac) 11 10-04-2006 02:02 PM
Select an area to turn down volume GtrDude 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-26-2003 11:35 PM
