Correct 2nd drive installation?
OK, I put my second drive in as the slave to my first drive, both on the same IDE channel.
BIOS says it is there as the slave, and Windows says it s there, operating correctly with the correct drivers etc. I have no drive designation for this new drive As in A: B: or C:. I had no prompt to format the new drive, and cannot de frag or anything, it is simply there. IS this drive in the right spot? My other IDE channel has a CD ROM as the primary drive. Also, I didn't get an installation disk with my new drive, unless I lost it which i don't think i did. |
Re: Correct 2nd drive installation?
no drivers are required for hard drives. only the controller requires drivers.
assuming you have your jumper settings correct - if you can't see the drive, its probably not formatted. go into dos mode and do this. if you have partition magic, its even easier...
i love my apple iPhone! |
Correct installation procedure | ctspell | macOS | 1 | 12-16-2011 06:25 AM |
Correct MBox 3 pro drivers and pt9 installation | jamiet | macOS | 0 | 07-29-2011 10:48 PM |
Correct Installation? | youngas75 | Pro Tools TDM Systems (Mac) | 4 | 09-18-2007 05:19 AM |
correct way to defrag audio drive | b mcgibney | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 14 | 10-07-2003 01:35 PM |
g4 400 firewire.....ate anther drive....correct FW enabler? | c zarkos | Pro Tools TDM Systems (Mac) | 8 | 11-17-2002 08:38 PM |
