#21
![]() Quote:
![]() Nice one - thanks man! ![]()
Pro Tools 2024.10.2 macOS 15.3.1 iMac (24-inch, M1, 2021) (16GB RAM, 1TB SSD internal) Samsung 990 PROs - Acasis TBU405 Pro M1 enclosures Apogee Ensemble Thunderbolt ( ![]() |
#22
It's a nice app for breadth of what it can do, but I find myself screaming at it's lack of good plotting etc. I'm used to things like Grafana and Performance Co-Pilot in the open source/Kubernetes/Linux monitoring world.
#23
![]() Quote:
I keep looking at my Menu Bar every 10 seconds now. ![]()
#24
By the way, after updating my 980 and 990 PROs, I don't get -9013 errors anymore!
#25
That is both good and scary.
#26
Hi Darryl,
I've (finally!) tried to update firmware via the Etcher route you described so clearly. Etcher worked as expected with the latest 980 Mac ISO image: the USB mounts as 'Samsung' after creation, and seems to contain all the relevant files, however my Mac Pro 7.1 does not recognise it as a bootable device - no 'EVIboot' option shown on startup with 'Option' held, just the two Mac OS partitions (Ventura and Monterey) and time machine backup are shown. Any ideas? I did use the pathetic Magician software to confirm firmware versions for the Samsung drives (980, Qvo 860) and both are out of date, so I'm keen to get this sorted, but really don't feel comfortable using Terminal. Thanks in advance, Martin.
Martin Nichols PT Ultimate 2023.9, Mac Pro 12-core 7.1, 224Gb RAM, Monterey 12.6.8 or Ventura 13.6.1, HDX card with Avid HD interfaces. |
#27
How did you create the backups on those drives and why do you think they should be bootable? With APFS (vs HFS+) volumes you can no longer create incremental/updated clones that are bootable. Thats been discussed on DUC before and lots of info is on the interwebs.
#28
![]() Quote:
Clearly I'm missing something fundamental, so apologies for my inexperience. Do I need to install a Mac OS onto the USB drive first, before using Etcher?
#29
![]() Quote:
You are trying to boot this USB SSD stick on your Intel Mac Pro 7.1 right? Try multiple USB ports on the computer. Try removing as many as possible other USB devices. hubs docks etc.. Try doing a full hard down power off power and start up. Quote:
Try downloading the .iso install image again from the web site, try erasing the USB SSD using macOS Disk Utility just create any file system on the drive, just to see it works OK for Disk Utility, Etcher will overwrite that anyhow. Reimage it with Etcher and try installing any of the other firmware updater files on the website to it. Even if you don't have those drives you are just testing if you can get any ISO image on the USB SSD drive to boot. Last edited by Darryl Ramm; 07-29-2024 at 02:34 PM. |
#30
Thanks for the suggestions Darryl.
I've done some more testing, and the EFI boot does show up as a boot option on an older MacBookPro running Catalina, so the USB stick(s) seem to be written correctly. I have a nasty feeling it's to do with the T2 security chip and/or Ventura as used on the Mac Pro 7.1. I have checked settings by booting into Recovery, and in the security utility booting from an external drive is allowed, and security is set to 'none'. Any further thoughts appreciated. By the way, do you happen to now if it's possible to update firmware with the drive mounted in an external enclosure? I have an iMac with two Samsung SSDs (an Evo 850 and an Evo 860), both connected externally in a Sabrent USB-C enclosures. Should/could this work, or will I have to dig out an ancient 2010 cheesegrater and mont them on the internal SATA bus? Thanks again, Martin.
Make sure your firmware is up to date! | DigiTechSupt | Artist Series | 0 | 03-10-2011 11:10 AM |
002R - How to check firmware version?? | silence2-38554 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-07-2009 06:04 PM |
Date for version 8? | Dopamine | Pro Tools TDM Systems (Mac) | 6 | 10-13-2008 01:10 PM |
Most up to date PT version running G4 w/10.2.8?? | pitman | Pro Tools TDM Systems (Mac) | 7 | 02-17-2005 05:47 AM |
How can I check the 002R firmware? | macrocklin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-13-2003 08:56 AM |
