#191
HISSandaROAR SD069 TESLA COIL
https://hissandaroar.com/v3/soundlib...69-tesla-coil/ Zappy plasma arcs, glitches, tones, patterns!! 33% Intro Discount available until Nov 24th Check the vid: https://www.youtube.com/watch?v=hkq7wt3MByE HISSandaROAR UFX041 RABBIT TRAP https://hissandaroar.com/v3/soundlib...1-rabbit-trap/ Triggering brutal old spring steel rabbit traps... plus foley moves, rattles etc... 33% Intro Discount available until Nov 24th ![]() |
#192
BLACK FRIDAY SALE
To be honest I dont usually have a Black Friday sale... but I appreciate we are not living through normal times, and we all have to make our $$$ go as far as possible.... So all 169 HISSandaROAR SFX Libraries are on sale until Monday, with 33% discount. Please use discount code BFF33 at checkout https://hissandaroar.com/v3/all-sounds/ SD070 REVOLVE https://hissandaroar.com/v3/soundlibrary/sd070-revolve/ 33% Intro Discount available until Dec 8th Check MAKING OF vid: https://www.youtube.com/watch?v=VmQQinYsIKo REVOLVE has required a deep dive into using turntables to generate machine rhythms & friction gestures, using a classic Technics SL1200 and a Vestax PD2000 with a collection of textured objects. The Vestax proved especially invaluable as it has ultra pitch +/-50% plus adjustable start acceleration and braking, as well as reverse! Originally inspired by Graham Dunnings ‘mechanical techno’ I have pursued friction based sound generation, with contact mics attached to cardboard and plastic which acts as a stylus – amplifying the form of the object as it revolves… Objects include two gongs, a ribbed plastic rubbish bin, a glass bowl, metal dish, multi level serving tray, wheel rim, cake mixer bowl, two waterphones, a paella pan, gaffer tape, a plastic colander, two fan safety covers, two sprockets and some leftover parts from the Tortured Dryer sessions. Centering the object creates fairly consistent rhythms but two tactics led to some off kilter patterns: asymmetrical objects, and placing the object slightly off centre. Recorded 32bit 192kHz using a pair of Trance Audio Contact Mics this new library is now released 24bit 96kHz with full UCS metadata & photos. This library contains some unique textures, rhythmic noise and gestural friction which due to noise content respond well to processing… |
#193
Releasing a new #free #soundlibrary next week, as a Xmas Present
for everyone who supported HISSandaROAR this year! Join the email list if you'd like a copy: https://hissandaroar.com/v3/subscrib...il-newsletter/ ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
#194
HISSandaROAR SD071 SPRING IMPACTS
An awesome collection of hits & impacts - check the Making Of vid: https://www.youtube.com/watch?v=uZ5C4XvrdeY https://hissandaroar.com/v3/soundlib...pring-impacts/ 33% Discount available until Feb 1st I spent over three years collecting springs, and then mounting each spring in a way that it could freely resonate under tension. The first output from the collection was the Impulse Response library: IR005 SPRINGS Over the last four months I have been recording the spring collection and am both excited & relieved to finish & release this new library of SPRING IMPACT sounds, which explores a range of percussive hits. The springs range from very short small diameter (130mm x 15mm) through to very long (2800mm x20mm) with decay up to 25 seconds. Hits were performed with hard mallet: full free sustain, then damped, and then very damped – the latter providing meaty solid metal impacts. To add interesting pitch, I also captured hits with a metal bridge attached to the spring. These work almost like a tongue drum – the ‘prongs’ generating pitch, which is transmitted into the spring. Struck with a hard mallet they ring out beautifully, but struck with a soft mallet they instantly created unique subtle stings. In a few cases (the huge auger springs, thunder drum) I also captured handling, movement and some friction moves – the auger with threaded rods woven through them, sounds massive when wrangled! These are very useful, powerful sounds applicable to elements of practical effects but equally applicable for designed sounds, stings & impacts as well as musical percussive elements. Captured 192kHz 32bit with a pair of Trance Audio Arcturus Contact Mics, every setup was a challenge to cleanly capture the vibrations without dampening resonance, while avoiding buzzy rattles. Released 24 bit 96kHz with photos of each setup and full UCS metadata. |
#195
Luftrausch | Framed Rhythms and Particles
We have just released two new sound packs: Framed Rhythms captures the sounds of a very special collection of natural skin frame drums, each with its own distinct character and timbre - offering a wide variety of playing styles and rhythmic patterns in loops and single/one shots. Framed Particles is a sound effects mini-pack featuring organic drones, cymbal swells, brush sounds, deep and lush drum hits, modulated bell sounds and glass and metal textures. Both sound packs can be purchased individually or together as a bundle. Use 'framed_earlyaccess' at checkout for an additional 20% discount for the next 2 weeks. Videoteaser: https://www.youtube.com/watch?v=QcChBfnJOZg https://www.youtube.com/watch?v=SmlzkMbTL_E ---------------- https://www.luftrausch.at/product/framedrhythms/ https://www.luftrausch.at/product/framedparticles/
www.luftrausch.at | Surround Atmospheres and Soundeffects |
#196
HISSandaROAR SD072 SPRING TONES & TEXTURES is now released!
https://hissandaroar.com/v3/soundlib...2-spring-tones Making Of vid: https://www.youtube.com/watch?v=SHin419uhx4 This library represents a huge collection of creative tonal & rhythmic source material, including: - Bowed friction tones via Double Bass Bow - Deep bass tones & growls via Landscape Ferrous x2 - Friction scrapes via Olliness Gong Friction Mallet - Friction scrapes via Finger slides - Friction scrapes via Threaded Rod - Rhythmic Ratchet via Bridge Slides - Grinds via Vintage Spinning Bird Toy - Mechanism rhythms via Windup Toy - Machine Rhythms via Battery Drill x Snare Brush - Feedback Tones via PeizoThing x2 Recorded 32bit 192kHz using a pair of Trance Audio Contact Mics Now released 24bit 192kHz with full UCS metadata & photos of each setup. NOTE: 33% Intro Discount until March 1st Making Of vid: DRILL x BRUSH only https://www.youtube.com/watch?v=hlGfr-tCcyc ![]() ![]() ![]() ![]() |
#197
FX029 Metal CD Rack Deconstructed
https://hissandaroar.com/v3/soundlib...-metal-cd-rack A new miniFX 7.05Gb Library created by deconstructing a metal CD Rack! Hits, impacts, plucks, strums & battery drill with snare brush Recorded 32bit 192kHz using Trance Audio Acturus Contact Mics Released 24bit 192kHz with full UCS metadata & photos 33% discount available until March 16th ($29 > $19) Check out the MAKING OF vid: https://www.youtube.com/watch?v=NpiLrKnoEp0 |
#198
Two new little UNITFX sound libraries are released:
HISSandaROAR UFX042 CLANK LOADBINDER aka BIG CLANK https://hissandaroar.com/v3/soundlib...ank-loadbinder I didn’t know what purpose this tool served when I found it, but the heavy clanking sound appealed thanks to its solid metal construction, weighing over 20kg. Turns out it is a “Twitch Load Binder – Lever Type, with Cradle Hooks” which are used to leverage and secure large cargo items when shipping via truck, ship etc… But regardless of its providence, it is capable of some heavy duty clanking! The first recording session involved freely held clanks, hits, shakes and movement, as well as suspending it on bungy cords & attaching a few rattly metal clamps for variation. Similar actions were also performed on a heavy wood surface, and then on concrete. Recorded 32bit 192kHz with Sound Devices MixPre10-II and Sanken CUX100Kand MKH8050 microphones Released 24bit 192kHz with full UCS metadata and photos of each setup. ![]() ![]() ![]() ![]() ![]() ![]() ![]() HISSandaROAR UFX043 PIPE BELL TWO https://hissandaroar.com/v3/soundlib...-pipe-bell-two This heavy metal pipe was rescued from OVERFLOW junk store and was originally a section of pipe from a well, accessed by farms for both drinking water & irrigation. Suspended this pipe 'rings like a bell' and accordingly was played using: - soft woven mallet - heavy rubber mallet - hard wood mallet - metal percussion mallet Multiple full ring outs were captured with each mallet, as well as dampened variations. Recorded 32bit 192kHz with Sound Devices MixPre10-II and Sanken CUX100K mics and MKH8050 microphones Released 24bit 192kHz with full UCS metadata and photos of each setup. |
Downloadable Sound Library | Nick10101 | MIDI | 0 | 06-13-2010 11:39 PM |
Does ProTools come with a sound library? | scleroshock | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-29-2009 10:20 AM |
Sound FX Library - Recommendations | Mubeau | Post - Surround - Video | 7 | 10-21-2008 09:41 AM |
Sound fx library recommendation! | javi79 | Post - Surround - Video | 8 | 05-14-2008 10:59 AM |
Looking for a sound library with ... | soundthinker | Post - Surround - Video | 2 | 03-28-2006 07:51 AM |
