Missing DigiRewire.dmp from Plug-Ins
I'm not sure how this plug in went missing, but I need Rewire working to run Soundminer effectively. I've tried trashing prefs and reinstalling both PT 8.0 and 8.1 from their .dmg updates and no joy. Any suggestions?
thanks much, - A. |
Re: Missing DigiRewire.dmp from Plug-Ins
I had similar problems, if you do not have reason or did not install reason adaptive that came with most protools ignition packages..you can download the latest version of rewire here http://www.propellerheads.se/download/updates_rewire/ This is probably your best bet.
Hope this helps! |
I've had the same problem. I cannot use Reason in ReWire mode, and I downloaded the most current version of Reason from propellerhead site and still no dice.
I ended up doing an clean uninstall and then reinstalling. That brought digirewire back, but it crashed PT on boot up. A bit of research yeilded that if you have melodyne, but haven't updated it, that will cause your DigiRewire.dmp to crash PT. Deleted all melodyne files in HD/Library/Application Support/PropellorHeads/Rewire and everything works again.
Digirewire missing in plugins list | masokotanga | Windows | 0 | 02-23-2012 11:19 AM |
Digirewire not in plug ins list | patswope | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-27-2011 08:00 PM |
DigiRewire missing? | danander11 | Pro Tools 9 | 6 | 01-22-2011 10:24 PM |
Unable to see DigiReWire plug-in | SwirlyKing | Pro Tools M-Powered (Mac) | 4 | 12-03-2007 11:58 AM |
DigiRewire Missing from Aux Insert List | Jack Secret | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 08-04-2006 06:40 PM |
