Unable to see DigiReWire plug-in
I have Pro tools Academic 7.3 and Reason 3. Pro Tools cannot see the DigiReWire plug-in. It has worked in the past, but occasionally when I start up Pro Tools, it doesn't see the plug-in suddenly. Sometimes restarting will do it, other times I've replaced the plug-ins folder and it works, but it's really unpredictable. Eventually I got it working regularly. All this was happening on a Powerbook G4 OSX 10.4 through 10.5. It worked in both systems. Now I've got a new iMac 2.8 GHz and I've installed the programs and now no matter what I do it does NOT recognize the DigiReWire plug-in - even though it's there. When I open a Pro Tools document that had Reason connected to it I always get this message:
Track "Inst 1" Insert 1 ("Reason") has been made Inactive because the plug-in is not present in the plug-ins folder Now it seems I can't do anything to fix it. I've reinstalled everything and tried everything I can think of. What is causing this supremely frustrating condition? |
Re: Unable to see DigiReWire plug-in
Not sure if this will work but it may be worth a try. Go to the Library/Audio/Plugins/VST. If it is there, copy the Reason plugin and paste it into DigiDesign plugin folder.
J |
Most likely, you need to download and install the Reason 3.0.5 update.
Thank you for the responses. There was not a Reason file in my VST folder, so I couldn't do that. I will upgrade Reason tonight and see if that fixes it.
Digirewire not in plug ins list | patswope | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-27-2011 08:00 PM |
Digirewire, impossible to found it in my plug ins insert... | jeananto | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 04-28-2010 05:27 PM |
Missing DigiRewire.dmp from Plug-Ins | stcowboy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 10-13-2009 08:06 AM |
DigiRewire Plug-in not allowing Pro Tools 8 to open | drdolla80 | Pro Tools TDM Systems (Mac) | 7 | 01-24-2009 11:00 AM |
7.4.2 locks up with DigiReWire.dpm in Plug-ins Folder | PTrust | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-25-2008 07:26 AM |
