Old 03-15-2018, 11:17 PM
nibtgom nibtgom is offline
Default Mbox mini 3rd gen unable to monitor playback after phantom is activated?
My mbox has worked fine since i got it several months ago, this is very sudden change to the way it usually operates.
Today I activate phantom power on the mbox and now I can't monitor playback, of anything, including youtube, itunes, PT tracks etc. I've tried switching between headphones and speakers.
If I pull out the Mbox usb and reinsert it, playback will work again through the mbox, until I press in the phantom power button.
I reinstalled the last driver for version 1.3.4 released last October. (The new one is not compatible with my operating system). I did even turn the computer off and on again.
Would anyone have any ideas for me?
Any advice much appreciated! Thank you
SPECS:
OSX 10.9.5
MBOX Mini 3rd Gen
Pro Tools 11.3.1
Old 03-16-2018, 02:00 PM
Ben Jenssen's Avatar
Default Re: Mbox mini 3rd gen unable to monitor playback after phantom is activated?
Very strange indeed.
I'd be willing to offer a wild guess, though; the mini gets its power via usb. When you activate 48v phantom power, there might be a short drop in power, that could make the driver software lose connection with the hardware. Could it be that your mini is connected to a usb port with not optimal power? The built-in ports on your mac should be best.
Old 03-16-2018, 07:24 PM
I only have one functioning usb port at the moment but yeah you're completely right. I was not plugging in my powered usb hub because it was previously working fine without it, so i just plugged it in and that +48 issue not longer occurs.
wooo thank you very much
Old 03-16-2018, 07:28 PM
I'm glad it worked out!
Mac OS X 10.8.5 unable to recognize Mbox Mini Steve Stokes FireWire & USB Audio Interfaces (Mac) 3 01-10-2014 10:53 AM
Unable to locate hardware. Mbox mini. Sears Pro Tools 10 10 03-12-2012 12:35 PM
MBox Mini 3 + PT8LE 'Unable to Recognize...' bjohnny 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 03-27-2011 07:30 AM
PT Unable to Locate Mbox 2 Mini B-Rob 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 01-24-2011 06:05 PM
Bad monitor jacks on MBox 2 Mini? bonniejay 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-01-2007 02:49 PM
