Old 04-06-2001, 10:47 PM
paganini12 paganini12 is offline
Default Analog outputs 3-8 still not working
I posted a while back with a problem of getting no sound from outs 3-8. I tried everything mentioned as a possible remedy and nothing worked.
Well, I have upgraded my computer with a new motherboard and processor, switched to Windows ME, upgraded to PTLE 5.1 and still no luck. (was doing all these anyway, is one reason I've waited to fix the trouble. Was hoping it had something to do with my old slow Celeron Win 98 first edition configuration)
Everything else works fine. All inputs are good, Outputs 1 and 2 are crystal clear. Is there something I'm missing? Some way to tell the computer, hey you got more than 2 outputs over here!
Like I said, I've tried every possible signal routing there is, checked the cable for damage, reseated the cable to make sure it is in good, but nothing works.
I don't have to have those outputs, but dangit, when I buy something I expect it to work, you know?
If anyone has any suggestion other than sending it to Digidesign for them to check it out, please tell me. I really don't need to have the unit gone for any length of time. Ran into that turning into 3 months longer than expected with a Seymour Duncan bass head a while back.
Thanks in advance
Tim Umstead
Old 04-07-2001, 09:20 AM
tchipman tchipman is offline
Default Re: Analog outputs 3-8 still not working
if I were in your shoes I'd take it back where I got it and get a new one. That sounds like a defective unit. I wouldn't put up with that for a minute.
Old 04-07-2001, 11:47 AM
TriAxis TriAxis is offline
Hey Pag
In the mix window, above the faders there is a box that says some crap. like 1/2 if its a stereo track. 1,2, adif something like that.
Its your output router. click on it.
A box appears its says no output, output and bus. highlight output, then go down to analog 3 mono. click on it then your sound for that track should go out of the #3 output.
Make sure your cord is connected to #3 and listen.
If this doesnt work, I dont know wants wrong
TriAxis
TriAxis Wuz Here!
DIGI003 Rack+ Factory
Intel Q6600, ASUS DH Deluxe, 8 GB DDR2 800 Mhz RAM,
ProTools LE 10 on Windows 7 64 Bit
Old 04-10-2001, 02:57 AM
IOP Drummer IOP Drummer is offline
Would this cord connected to #3 go into my ear??
Mike Blanchard
Engineer
Old 04-10-2001, 05:07 AM
Damage Damage is offline
I am currently experiencing the same problem.
My outs 3-8 were working fine until I installed the new WaveDriver 1.7.
Maybe you have installed this program as well?
Thanks in advance
Tim Umstead
S/PDIF & Analog Outputs gclef101 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 09-12-2009 03:18 PM
more analog outputs BaileyBass Pro Tools TDM Systems (Mac) 2 06-13-2007 05:45 PM
Analog Outputs Edson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-03-2007 11:48 AM
Is there a way to get 16 analog outputs? Avi Bortnick Pro Tools M-Powered (Mac) 1 01-19-2007 11:25 AM
Analog outputs -question lumpo ICON & C|24 1 01-29-2002 12:44 AM
