Old 05-29-2003, 07:14 PM
nerdyrocker nerdyrocker is offline
Default 001 Outputs not working?!!?
Pro Tools works. I can play and meters/automation is everywhere. No audio is coming out of my speakers. DAE is selected, I/O Settings is correct. Connections are tight. I can even get record levels but no audio is heard. Please help! [img]images/icons/confused.gif[/img]
Less talk, more rock!
Old 05-29-2003, 07:34 PM
464444 464444 is offline
Default Re: 001 Outputs not working?!!?
check and make sure all of your channel strips are set to output 1-2 not bus 1-2 also check your master output and the actual output connection of your digi001 that's connected to either your speakers or your hardware mixer if you are using one.
Good luck!
Old 05-29-2003, 07:47 PM
They are all on the main outs and all connections are good. Thanks but I checked that already.
Old 05-29-2003, 08:28 PM
where02190 where02190 is offline
1. is the monitor volume up?(front panel center right)
2. Is the monitor mode button in the out position? (to the left of the volume control, in position sends whatever is in inputs 3/4 to the monitor outs)
3. do you have the faders up, mutes off?
Hope this is helpful.
Old 05-29-2003, 08:41 PM
I am using the Main Outs (analog 1+2) so the monitor volume and button doesn't matter. All the faders are up and mutes are off. Thanks though.
Old 05-29-2003, 10:07 PM
Doc Doc is offline
Check the Digi cable on the back of the 001 and on the back of your Mac. The same thing happened to me once and it was caused by the cable not being fully clicked in place.
Old 05-29-2003, 11:50 PM
Once again on the front of the digi001 make sure that the input monitor mode button is set to the out position and not pushed in every once in a while this button gets overlooked. The other thing you may want to try is make sure that the digi001 volume is turned up and not muted in the sound control panel.
Good Luck!
464444
Old 05-30-2003, 05:51 AM
I uninstalled the cable and re-installed it, didnt help. The monitor button is out and in the control panel the volume is all the way up.
Sorry but thanks again.
Old 05-30-2003, 06:44 AM
neil_mcdermott neil_mcdermott is offline
i have seen a DIGI001 o/p fail before but it seems unusaul that both 1 AND 2 have gone. Check it is not some software problem.
trash DAE prefs (whole folder)
trash digisetup prefs
trash pro tools prefs
restart
zap the pram
rebuild the desktop
amazing how many probelms that fixes...
Neil McDermott
http://www.neilmcdermott.co.uk/
Old 05-30-2003, 10:36 AM
what is zapping the PRAM and rebuilding the desktop? those are new terms. is it apple+option+p+r during restart?
thanks
Outputs not working theberzh 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-15-2013 02:49 PM
MBox Pro 3 Outputs not working xkleenexk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-05-2012 04:10 PM
192 outputs not working right? duskb Pro Tools TDM Systems (Mac) 4 07-29-2007 02:45 PM
Digital outputs not working qbert1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-10-2002 04:52 PM
Analog outputs 3-8 still not working paganini12 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 04-10-2001 05:07 AM
