Old 09-28-2009, 12:30 AM
Farmer Dave Farmer Dave is offline
Default POD Farm changing settings when it shouldn't
10.5.8
PT 8.0.1
2.66Ghz Quad-Core Intel Xeon
POD Farm 1.11
POD Farm has really been doing some strange things. It doesn't always recall the settings correctly, and one thing I can re-create 100% of the time.
1) Put POD Farm in dual-amp-mode.
2) Make note of the settings & save the session.
3) Close & re-open the session.
4) The amp model in the 2nd chain, will have changed from where I saved it.
Now what's wierder, is if I click the plug-in insert on the track (to display & hide the plug-in), the amp in the 2nd chain will change every time the plug-in opens/displays.
Is this happening to anyone else?
Old 09-28-2009, 12:37 AM
Default Re: POD Farm changing settings when it shouldn't
I also tested this with a preset that is only 1 channel.
1) Save & closed the session
2) Re-opened the session
3) The settings are all different. I have no idea what it's recalling, but it's certainly not what I saved with the session.
Old 09-28-2009, 04:11 AM
Drew Mazurek's Avatar
Been this way for me too from day one. Once you get it the way you want it, save it as a preset, and then you have to recall it every time you open it. Even then, I can get a different result each time I recall the preset!!! I've been hoping for an update to fix it, but it's been around for the last few.
www.drewmazurek.com
Old 09-28-2009, 09:39 AM
Thanks for confirming!
IO Settings keep changing LCM Technician macOS 1 02-06-2013 08:01 AM
I/O settings changing on its own will. MacGreginator Pro Tools 10 0 09-14-2012 05:46 AM
Settings Changing on Their Own NJSoundguy VENUE Live Sound Systems 5 11-14-2011 08:47 AM
Changing I/O Settings in PT8 fooloof 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 09-17-2009 05:24 PM
changing IRQ settings mfym 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-20-2000 03:24 PM
