Pro Tools ARA problems
I've been using Melodyne for a lot of years for pitch, timing etc. and usually on a lot of tracks. But I can't fully understand the workflow and idea of the integrated Melodyne.
How about opening Melodyne in a separate window? Am I missing something or is it really not possible? I want a big separate window on my second screen so I can see and edit the stacks. I get an error every time I open a session with ARA: "Warning: The document being loaded was damaged and has been repaired automatically. To be safe, check your edits" Hello!! I have 25 channels with Melodyne, should I check all the edits??? And also getting the message "Saving ARA data" ...not possible to hit "play", you have to wait for it to finish. Time consuming! Anyone have a solution? |
Re: Pro Tools ARA problems
Carry on using Melodyne as an insert and give Avid a few years to iron out the ARA thing.
You don't state which version of PT you are using.
PT 2022.10 fixed a lot of the "Saving ARA" messages. Dominic
MacBookPro M1Max 16" 10/32 64GB 2TB, Ventura 13.6.6, Pro Tools 2023.12.1, Carbon. |
I use 2022.10.01
In the same way they ironed out all the issues with Elastic? Still waiting for that day…
Heh, its a good thing we can still use Melodyne the old way. For quick fixes, ARA is dandy, but I suspect as much as Avid tested before releasing it to the world, there were(and probably always will be) surprises. Just glad ARA didn't screw up the old method
Pro Tools Problems | Vercingetorix | Eleven Rack | 24 | 01-13-2022 11:35 PM |
Pro Tools LE 8 with Mac OS 10.7.5 Problems | Matze Lindner | macOS | 2 | 04-01-2013 05:07 PM |
Pro tools 9 problems. | antonio iannella | Windows | 3 | 05-14-2012 07:22 PM |
Computer Problems vs Pro Tools Problems | mudlake slim | Pro Tools M-Powered (Win) | 1 | 07-14-2006 08:09 PM |
