003r Standalone
Is it possible to use my 003r in some kind of slave/standalone mode? I am working on a Logic project and the producer wants to use my 003r as a second interface (Fireface800 is the main unit). I can't seem to get the 003 to do anything except power up unless it is connected via firewire, and when both the 003 and the Fireface are connected the Fireface freaks and displays a sampling frequency of -1073747! Looked in the manual etc. cannot find anything. The producer wants to continue to use the Fireface as the main interface. Thanks, Bryan |
Re: 003r Standalone
The 003 products do NOT have a standalone mode and will not work that way. Same with the mbox products. They all will only pass audio to and from the computer.
Your only option in this situation is to use the 003 as the main interface for Logic and the RME as the expansion unit via Adat. |
Re: 003r Standalone
Strangely enough, I use the revers of this when I need to use PTs. I use the i/o of the RME for the adat i/o of PTs and of course the RME clock. Sounds great and I don' have to use the 003R pres.
Matt McKenzie-Smith mattrixx.net SourceConnect - mattrixx AVID Collab user - mattrixx MacStudio Ultra / LogicProX / IzotopeRX10+ / SourceConnect / MelodyneStudio5 / WAVES Mercury / NI KompleteUltimate / ProToolsUltimate / RME UFX, UFXII, Babyface / AVID S3 + DOCK / Barefoot MM27 gen2 / Barefoot FP01 |
Re: 003r Standalone
You can use the 003 in stand alone. go in the aux with 1/4" cables go out the main to your speakers. hit the aux button on the front and (no computer needed)... good luck
Re: 003r Standalone
Well, that sorta works, but it's not truly standalone and I think they were trying to expand the amount of inputs, etc.
Re: 003r Standalone
Ok... You are right. it doesn't work for expansion but it is a nice way to run audio threw your 003 with no computer needed.
Re: 003r Standalone
Thanks everyone. Seems a shame this feature is not offered.
And Digidesign, how about an input mixer app similar to Motu/Fireface? Would make my life a lot easier... |
Re: 003r Standalone
www.HellfireBeats.com UAD 2 Apollo Quad w/Thunderbolt 3, UAD 2 Satellite Octo TB3, UAD 2 Octo PCIe, Avid S1, Neve R6 500 Chasis, Neve Portico 511, Neve Portico 551, Dangerous DBox+, Focal Trio6 Be, Neumann TLM49, Akai MPC 2000XL, Akai MPC X, Mackie 1202VLZ Pro, Akai Advance 61 Pro Tools 2021.12 Mac Pro 7,1 2019, 8 Core, 48GB RAM - MacOS 11.6.2 16" MacBook Pro 2021, M1 Pro, 16GB RAM - MacOS 12.1 27" iMac, Late-2012, 3.4GHz i7, 24GB RAM - MacOS 10.15 |
Re: 003r Standalone
As far as I know the only thing that's ever had a true stand-alone mode was the 002 (not the rack). However I'm not sure you can use the digital inputs in stand alone mode. I've used mine before as a little mixer for some acoustic practicing, but think I only had access to the 8 analog ins.
Dell T5810. Harrison Mixbus 32C. Haven't used PT since 2015 and never been happier. |
Re: 003r Standalone
CME,
I'm pretty sure you're right about the 002 being standalone in analog only. Basically functioned as an analog 8 channel mixer, which is kind of handy. I wonder why they didn't continue that with the 003. |
003r standalone? | bryannew | macOS | 4 | 04-25-2012 04:27 PM |
Problems with Standalone ASIO Driver version 8 for 003R | Kurt Briggs | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-14-2011 08:32 AM |
Problems with Standalone ASIO Driver version 8 for 003R | Kurt Briggs | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-13-2011 10:39 AM |
7.1 with 003R...? | WKG | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 09-25-2007 03:38 PM |
Tascam's GVI in Standalone Mode with the 003R Interface. | luken | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 06-10-2007 10:16 AM |
