Old 04-24-2010, 09:05 PM
Luigi82's Avatar
Luigi82 Luigi82 is offline
Exclamation Loops don't fit with grid (if using zoom)
Hi! I'm new here, but I've searched for the problem I have, and I didn't find anything.
My micro-problem maybe is silly, but the thing is that sometimes I use the "loop..." option, the loop doesn't fit with the grid (but the original region does). It provokes a bigger error for each loop I add. It's a very small error, but with 20 loops it's out of tempo.
I noticed about it by using the maximum zoom. I think a couple of images will be better, so here they are:
my loops -> IMAGE_1
zoom at the end of the loop -> IMAGE_2
could anyone help me with this, please?
Let me know
AMD Ryzen 5 3600 3.6 GHz + 32 GB RAM
Windows 10 (64 bits)
MBOX 2 PRO + Pro Tools 10
Old 04-24-2010, 09:57 PM
685 685 is offline
Default Re: Loops don't fit with grid (if using zoom)
Not sure I understand what's going on with your problem.
But, are you recording the loops into Protools or importing pre-made loops?
Old 04-24-2010, 11:13 PM
DJ Hellfire DJ Hellfire is offline
Looks like your tempo is too slow. You can try stretching those regions to the nearest bar with elastic!
www.HellfireBeats.com
UAD 2 Apollo Quad w/Thunderbolt 3, UAD 2 Satellite Octo TB3, UAD 2 Octo PCIe, Avid S1, Neve R6 500 Chasis, Neve Portico 511, Neve Portico 551, Dangerous DBox+, Focal Trio6 Be, Neumann TLM49, Akai MPC 2000XL, Akai MPC X, Mackie 1202VLZ Pro, Akai Advance 61
Pro Tools 2021.12
Mac Pro 7,1 2019, 8 Core, 48GB RAM - MacOS 11.6.2
16" MacBook Pro 2021, M1 Pro, 16GB RAM - MacOS 12.1
27" iMac, Late-2012, 3.4GHz i7, 24GB RAM - MacOS 10.15
Old 04-25-2010, 06:38 AM
Luigi82's Avatar
I'm recording EZDrummer grooves.
I set the tempo (104) and I record the groove, as it plays 'a tempo'.
But this is not the problem, because it could happen even if I cut a region. I mean, in fact I did cut the region to make the loop, and I do this in grid mode, so the cut is in a grid line, so it fits in the grid, but when I apply the loop, just from the 3rd loop on, they are losing part of the end of the region, don't know why.
Do you understand the images I added? First is normal view. Second is zoomed to the max, so it's a very very very small error, but it is.
Thank you for your help, I hope we can solve.
Let me know
Old 04-25-2010, 06:55 AM
mano111 mano111 is offline
Sorry to say this but I think the loop tool is the worst tool ever invented in DAW history. I don't see any reason for using it at all.
To repeat your loop select between the grid lines and hit ctrl+D
Now that we have tool lock I don't even need to see that Icon anymore, Thank god.
i7 2600K @ 4.4GHZ -- Intel DP67BG B3 -- 8GB DDR3 1600 -- Crucial SSD
PTLE 8.0.4cs2 -- DIGI 003R -- DV toolkit -- Waves 9
Old 04-25-2010, 07:03 AM
It's good for when you're trying to write to a certain part of the beat. Like if I have someone in the stu and they are trying to come up with a hook, I can just loop the hook part of the beat and go make a sandwich or something instead of having to sit there and keep playing the hook part til they are done! Among other uses!
But for the OP, try recording a little past the 4th bar instead of just record exactly 4 bars. Then just copy/paste your 4 bars (omitting the little bit of overage obviously). See if that works. Shouldn't have to do that. For me, Pro Tools is always sample accurate, or extremely close to it. Might need a real slight fade here and they, but it's really close.
Pro Tools 2021.12
Old 04-25-2010, 08:03 AM
685 685 is offline
I've never used EZDrummer so I'm not sure. Wish I could help. Sorry
But just know that some "pre-made loops" may not be accurate as far as tempo and length goes. ex: a loop might indicate its 94bpm but may be something like 94.40 or 93.70, etc etc. OR if the tempo is correct in a 2 measure loop, the loop itself might actually be a tiny bit short of the full 2 measures as length goes..
In either case you will need to adjust the tempo or length for that single loop before you dub it. Time-stretching does work well on short loops. But you need to listen to make sure it sounds right. Not just looking at it on screen.
Whenever I record loop based tunes(keyboards, drummachines) I manually l line up things to the grid. Then I dub to extend the length of that part(s) as needed.
BTW, wasn't there a grid bug a while back?
Old 04-25-2010, 10:07 AM
rqstudio rqstudio is offline
I believe in prefs you can select: 'import with tempo' and while importing PT will make it's own grid. You don't select some arbitrary tempo and expect the sample to form to that grid. Then you can change it later and duplicate. (although some loops will not import tempo)
www.rickqueststudio.com
Old 04-25-2010, 10:28 AM
necjamc necjamc is offline
When you record the audio from EZD, are you making sure that the audio is trimmed to the measures prior to looping. THe midi data might be right on, but the audio may not be recording exact and you might have to spot it to a complete measure. I don['t use PT7 so in 8 it works right.
Old 04-25-2010, 12:31 PM
Luigi82's Avatar
Thumbs up Re: Loops don't fit with grid (if using zoom)
I'm saying from the beginning that I CUT THE REGION, it has nothing to do with recording a loop or with the tempo I use. Just take a region, in grid mode select a couple of bars, then cut and consolidate, and apply loops. That's all.
CTR+D works ! :)
Thank you to everybody, this forum and guys rulez
Let me know
Loops not locked to the grid ! HELP ! ley 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-10-2008 08:36 PM
Pasted loops gradually straying off the grid - help! bigdoghat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-20-2007 02:26 PM
GRID ERROR on ZOOM !! tasdu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 01-12-2006 12:46 AM
Fit loops to grid BeachDog 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 06-09-2003 11:10 AM
different grid values for different zoom levels? zeronine Tips & Tricks 0 02-12-2001 09:41 AM
