Old 11-17-2021, 09:40 PM
Knightrecording Knightrecording is offline
Default Solo not working
I just upgraded to PT 2021 and the solo buttons on any channel is not working.
They light up with no effect and none of the solo safes are on. Mutes are working just fine. Looking for suggestions to why this might be happening.
Old 11-18-2021, 08:00 AM
climber climber is offline
Default Re: Solo not working
No info abt your system. 🤦🏻*♂️
It’s working just fine here…
Al Hospers
bassist, vocal, composer, engineer
https://www.youtube.com/channel/UCCw...ogfR_7Q/videos
PT2023.12, OS X Monterey, Late 2013 MacPro, 6 core, 64 GB RAM, Orion Studio, Slate Raven MTi2, ISA428, ADL600, Distressor, Grace 501, Dimedio, Obsidian, One LA, BAC500, Harrison 32 EQ, UAD2 OCTO, Focal 6 be, Auratones...
Old 11-18-2021, 08:02 AM
More info would be helpful, but first check solo modes under the Options menu. If you're in AFL/PFL mode you'll need to define an output bus under the "output" tab in the I/O setup - not necessary if you're in SIP mode. Also, it's possible you've command-clicked the solo buttons to disable them.
http://www.richbreen.com
Solo not working deslog macOS 4 09-11-2018 12:36 PM
Solo isn't working right legacygt777 Pro Tools 10 6 04-03-2018 07:49 PM
Solo bus not working after bus changes Audioartist Pro Tools HDX & HD Native Systems (Mac) 0 05-28-2017 02:23 AM
Solo Clear not working on S3 jmkeane Avid S1, S3, Dock and Control App 3 10-09-2015 07:34 AM
Protools 10: mute and solo aren't working. (Solo safe is not on any of the tracks.) charlottewrinch macOS 2 04-14-2012 05:32 PM
