Default Source for Bounce to Disk Mystery
PT9 is working just fine on my setup. OSX 10.6.4. See signature for other details. Clean installation of OSX (erased disk) followed by usual updates to 10.6.4. Then PT 9. Waves 8 WUPPED clean install. Newest Altiverb.
However, I was VERY used to just a quick <cmd><opt>B to invoke the Bounce to Disk dialog, and then a quick <return> keystroke. I'm now finding that the bit depth and file type are retained from the last bounce but that the source drop-down varies indiscriminately from my Reverb aux send to the Main L-R. Many useless bounces have ensued. Any suggestions on setting and keeping the default bounce source as the Main L-R?
MacBook Pro 2.7 gHz i7, PT9 HD, Mackie ONYX Blackbird, AMEK/Neve 9098 Preamps, Schoeps mics |
Re: Default Source for Bounce to Disk Mystery
Great question - I'm pretty much in the habit of making sure everything's the way it should be before a bounce as I've been burned too. I did some experimenting last night with this in the I/O to see what sets the default bounce but it had no effect. And it can change with the session. Does anyone know what determines the default bounce source??
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
Yeah, that's driving me nuts, too...
I even have the bigger problem, that if you want to export a Quicktime-movie and change the settings, you will have to do a "normal" bounce first to chose the bounce source you want, because in the movie-export-dialogue, you are not able to chose anything else besides busses (the interface outputs are greyed out). For me, that's a major bug, at least not thought through, because of what help are all the great new features if you're having trouble exporting your work properly? |
Whats the Difference between Bounce to Disk Source -> Physical Output vs -> Output | Epik Productions | Pro Tools TDM Systems (Mac) | 8 | 05-03-2013 12:48 PM |
Default Source for Bounce to Disk Mystery - asked again | Neesley | Pro Tools 9 | 2 | 04-21-2011 06:23 PM |
Default Bounce Source on 1 session | KingFish | Pro Tools TDM Systems (Mac) | 6 | 02-04-2011 11:34 AM |
Bounce To Disk - Clock Source Important? | Paul_Caruso | Pro Tools TDM Systems (Mac) | 21 | 03-10-2008 12:17 PM |
PT 5.1 bounce to disk mystery | sphereman | Pro Tools TDM Systems (Mac) | 4 | 04-02-2001 09:34 AM |
