Delay Comp issues since moving to 2022.12
Been on HDX/Ultimate for years.
Over the holiday I upgraded to a Mac Studio M1 MAX. Using newest version of PT (2022.12), under Rosetta. Updated all my plugs. Here's the thing- I immediately started noticing some weird phasey stuff happening when I parallel process. Same plugs I've always used to do that- except it was always rock solid on my old rig. I've tried all options of HW Buffer, etc. Nothing helps. Using UAD-2 Octo, and a Quad Satellite. The HDX/OCTO are in a Sonnet Chassis and connecting via thunderbolt. I should note that I am NOT using the Hybrid Engine at all. Is anyone else experience weird delay comp/latency issues with 2022.12? |
Re: Delay Comp issues since moving to 2022.12
Did you also recently update your UAD plugins? I've heard of timing issues with a recent batch of plugz. Or are you having issues with other non-UAD plugz too?
I'm using 2022.12 via Rosetta with a Mac Studio Ultra and haven't noticed any delay comp issues. BUT, it's ProTools, and they've had sporadic and unpredictable issues with delay comp since its inception. |
YES. I had to upgrade the UAD-2 software. I am definitely noticing it on the Chandler Zener. Haven't tried others yet. I believe its v10.1.
I am pretty sure I'm hearing a bit with Plugin Alliance stuff as well. Will do more testing today. |
AHH!!
I am have the most INSANE delay issues with the newest Pro Tools. HDX- Aurora n. it is samples off with all hardware inserts, and even my 2 lynx won't be synced. the only solution (sometimes) seems to be shutting EVERYTHING down, including a power cycle of the chassis. beyond frustrating. I've had this setup for years and it's never been an issue. hardware inserts are off by 34 samples. |
issues: HDX-2 (PT10) delay comp…. RTAS & hardware inserts | MixerGuy | Pro Tools 10 | 8 | 10-06-2014 03:21 PM |
Delay Comp issues | brdst | Post - Surround - Video | 1 | 02-01-2013 09:21 AM |
Strange Delay Comp Issues / Phasing | eledu | Pro Tools TDM Systems (Mac) | 0 | 07-17-2012 08:36 AM |
Reamping with PTHD - delay comp issues | DUCHUNTER | Pro Tools TDM Systems (Mac) | 14 | 10-02-2011 04:05 PM |
8.0.3 serious delay comp issues! | magnoman | Pro Tools TDM Systems (Mac) | 7 | 01-09-2010 12:16 PM |
