001 to MBox
Hello,
Can 001 files be opened/edited using an MBOX? thanks, Donovan |
Re: 001 to MBox
Quick answer: Yes
Long answer: Since both the 001 and the MBox use ProTools LE as the software, they can read the same documents. If all of the audio is routed to outputs 1/2, everything will come out OK (don't worry about bus tracks, that has nothing to do with your hardware.) If you had a special headphone mix going to outputs 3/4 on your 001, you can not play those tracks unless you reassign them to the available outputs for the MBox. If I'm not mistaken, ProTools will inform you of this conflict when you try to open the file. But all and all, you can transfer the same session between a 001 and an MBox (or a MIX system and an HD system for that matter.) It's like if we both had Microsoft word, but I had a color printer and you didn't. You could open the same files, you just won't output it the same way. Peace H |
Updated Mac Drivers for Mbox, Mbox Pro and Fast Track Ultra now available | Avid | Technical Alerts | 0 | 10-30-2012 04:24 PM |
Mbox mix knob always plays a drum track,Mbox 2 and Pro-tools LE 8: | Haezel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-20-2011 02:58 AM |
Digi Tech Suppport? Pfft!!! Mbox/Mbox academic Questions | WestPhillySoulzition | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-17-2008 01:03 PM |
Mbox 2 Pro vs Mbox latency - Mbox 2 Mini pro? | marcnyc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-28-2006 08:18 PM |
Mbox - Routing the computers audio through the mbox ie. CD Rom, system sounds | brownmusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-30-2003 03:22 PM |
