VCA volume control
Ok, tell me I'm missing something. I select the tracks I want to group, group them. In the "Modify Groups" window I make it a mix group and assign it to a VCA fader (previously created). Under the attributes tab the main volume and mute are selected and grayed out. Under globals the main volume and mute are selected as well as Record enable, input monitoring, solos and automation mode. Click ok. Now back in the session the mute on the vca mutes the proper channels, the solo solos, rec arm works but the fader does nothing. I use VCA's in live mixing all the time so I'm very familiar with the concept. What am I missing?
Re: VCA volume control
Probably the same thing I missed--are your slave tracks set to automation off? If so the faders won't move when you move the VCA master. Try changing the slave tracks to "auto-read", should work then.
Irwin |
That was the problem, I had auto suspend turned on. Thanks!
DB-33 Volume control | siscok5lyt | Windows | 5 | 03-06-2013 01:53 PM |
Volume Control | JustGotPaid | macOS | 8 | 09-05-2012 09:45 PM |
Volume control | ice0-5 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 12-29-2010 02:59 PM |
Volume Control 002 | rcourell1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-28-2004 08:53 PM |
Volume Control of an IAC bus | stevemusic | MIDI | 1 | 12-11-2003 06:25 PM |
