Old 06-29-2004, 07:05 PM
soulcatcher soulcatcher is offline
Default Mbox Peak / Peak Light Issue
Ok, so I was testing out my new FX box today and I triggerd the Peak Light on my MBox.... however, now the Peak light will not go off and everything coming out of the Mbox is distorted.
Here is what I have done so far...
1) I have unplugged the Mbox for the USB port, reconnected, clicked to the line channel and the Peak lights stay red.
2) I've restarted my entire system, clicked to the line channel on the mbox and still the peak lights stay red.
3) I have removed all audio inputs to insure that I'm not getting a ground issue, restarted and the peak lights stay red.
4) I've removed ALL inputs / outputs so it's just the Mbox connected via the USB (for power), switched to the line channel and and the peak lights are still red.
Finally, I looked in the knowledgebase but couldn't find anything the was anywhere near this issue. Ineed some serious help here, please. To be frank, I'm a little worried.
Thanks.
Old 06-29-2004, 08:01 PM
Bazzle Bazzle is offline
Default Re: Mbox Peak / Peak Light Issue
Your going to have to update the firmware.Go to C:\Program Files\Digidesign\Protools\Protools Utilities and click the blue firmware updater icon.If that doesn't work do a Repair installation in
ADD/REMOVE PROGRAMS.
Bazzle
Signal peak/distortion/db meter peak when recording enabling track on Pro Tools LE 8 hotgravy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-30-2012 10:49 AM
USB 3.0 and/or Light Peak JCBigler 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-20-2010 07:34 PM
A quick peek at New HD hardware and Light Peak... Citrin Pro Tools TDM Systems (Mac) 14 09-24-2010 03:43 PM
Peak Over Metering never light in 24bits record ppm Pro Tools M-Powered (Win) 0 07-23-2009 11:33 PM
red 'peak ' LED light stays on. zedhed 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 07-26-2001 09:32 PM
