512 stick of RAM - Will I be sorry?
I just bought a new 1.33Gig 12" Powerbook to use with my Mbox. Since it only comes with 256 in RAM, I needed to order more for it to be compatible with Protools LE. There's only one extra empty slot for me to add memory. I just ordered a 512 stick, to bring it up to 768. Will I be sorry down the line, i.e. - Do I have to order a 1 gig stick? I'll have up to 30 tracks on a song once I get set up right. Many Thanks!
Re: 512 stick of RAM - Will I be sorry?
i think you should be fine as long as your arent multitasking and use your buss's for some sends to ease up on the processing power.
I just got a iBook 1.2Ghz 12" and add 512MB stick.
It's the best in terms of price/value. the 1Gb sticks cost alot and for current PT version it's enough. Maybe in a year the 1GB price will drop and it'll cost less.
Just wanna do music, RA. |
Correction to stewie's comment - amount of memory has nothing to do with processing power. Most plugins use very little per-instance memory, sample players are an exception, they can use plenty of RAM, depending on what samples you load.
I have 768M in a 15" 1.5Ghz PowerBook. It's plenty for ProTools alone, and I can load quite a lot of samples into Reason.
Quad 2.5 G5, 4.5G RAM |
yes
reverbs also use ram
stick against stick in strike | harryk | Virtual Instruments | 0 | 09-06-2008 12:06 PM |
stick with the system I have? | glu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 03-18-2005 11:48 AM |
Do i stick with it or switch? | drummerfreak33 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 12-05-2004 08:42 AM |
Stick with old, or try new? | MarkPresti | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 02-26-2004 07:15 PM |
DTS & Stick of Joy... | Arno Peeters | Tips & Tricks | 4 | 10-13-2000 01:08 AM |
