Old 03-07-2002, 02:57 PM
joepanic joepanic is offline
Default Digi001 configure with Logic Audio PC?!?
Hi Folks,
i have a problem to configure the digi001 with logic. do i have to use asio for it? i did, but i got just 4 Audio Objects and 2 Outputs. The logic device manager works fine and all is correct configured, but... [img]images/icons/frown.gif[/img]
Can any1 gimme some help with it?
thanx in advance, jOe
Old 03-07-2002, 03:21 PM
flashbak flashbak is offline
Default Re: Digi001 configure with Logic Audio PC?!?
If your using the Windows version of ProToolsLE then no you can't use the ASIO driver. You need to use the Logic direct I/O driver instead. You also need to disable both the Digi's Wave driver and midi driver in order for Logic's direct I/O to work correctly.
Old 03-07-2002, 04:19 PM
How can i disable them? In the control panel/system menu? thanx, jOe
Old 03-10-2002, 08:28 AM
mattcohn mattcohn is offline
i also want to get digi001 and Logic (4.7 )working on the PC.
Please :
flashbak said "if using the Windows version of ProToolsLE then no you can't use the ASIO driver"...does that mean if i dont use PTLE I CAN use ASIO?? ARE there ASIO drivers for Digi001 on the PC??
i got the Direct IO driver working, but when I loaded a session made with ASIO, and set the tracks to use DIO instead, no plugin fx were available. Can one not use Logic built in and VST effects with DIO? if so, thats a disaster IMHO.
Joes question: how exactly does one disable the Digi wave driver and midi driver?
control panels/multimedia/devices/audio devices/audio for dg multimedia devices/props/ do not use audio features on this device
and for midi, the same idea but under midi devices
thanks.
xx
matt
Old 03-10-2002, 07:23 PM
Audiohead Audiohead is offline
Matt - there are no ASIO drivers for 001 PC. It shouldn't matter though - Direct I/O should work fine. Yes, all the plugins and softsynths work with DIO.
Plus, Logic should automatically offer to convert a song done with different hardware. It does for me... [img]images/icons/confused.gif[/img] In your case, when you open the song it should say something like "This song was created using ASIO - current device is Direct I/O. Do you want to convert?". It then sets the song up for Direct I/O.
Maybe this only came in with 4.72 or 4.8 - I'd suggest downloading the free 4.81 update on the Emagic site and see if that works.
Frank.
Logic Audio 4.7.2 and the Digi001 on PC Musikmn43215 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-11-2002 04:13 PM
G4 450 + Digi001 + Logic Audio 4.8 CHUMBAWUMBA General Discussion 2 12-12-2001 10:42 PM
Digi001 with Logic Audio or PT LE lfont 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-08-2000 05:35 AM
Digi001 & Logic Audio Paul Alexander 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 08-29-2000 10:50 PM
digi001 and logic audio toadman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 01-24-2000 01:15 PM
