Old 03-01-2007, 07:58 AM
bryanbassett bryanbassett is offline
Default What is the best internal audio drive G5 PowerPC
Hi everyone,
I'm looking to add an internal 2nd hard drive to my G5 PowerPC dual 2 gig machine.
I'm running HD2 with PT 6.2 (I know way out of date but planning to upgrade OS X and PT once I get this drive mounted and move some stuff).
As a follow up...what do you all like for firewire drives? I had mucho problems with my 2 LaCie drives.
See other posts...thankfully saved by Disk Warrior.
Thanks in advance for your posts
Bryan
Macbook Pro Intel dual 2.4 OSX 10.7.5 Lion PT 9.0.6 Mbox Mini / 003R
MAC G5 PPC OSX 10.4.9 / PT 7.3 HD2 - I/O 192 /Control 24
DELL Dual Core, MBOX/003R PT 8 WIN XP
Old 03-01-2007, 09:46 AM
Default Re: What is the best internal audio drive G5 Power
How About
Glyph Seagate Barracuda Serial ATA (SATA)
250 gig 7200
looks good?
bb
Old 03-01-2007, 05:49 PM
Barnabas Barnabas is offline
I buy my Seagate Baracudas from Other World Computing.
www.barnabas.com Barnabas MultiMedia
Old 03-01-2007, 06:15 PM
dr sound's Avatar
dr sound dr sound is offline
Default Re: What is the best internal audio drive G5 PowerPC
Try this :
http://www.newegg.com/Product/Produc...82E16822136012
or this:
http://www.newegg.com/Product/Produc...82E16822148136
Marti D. Humphrey CAS
aka dr.sound
www.thedubstage.com
IMDB http://www.imdb.com/name/nm0401937/
Like everything in life, there are no guarantees just opportunities.
Old 03-02-2007, 07:01 PM
Barnabas,Dr. Sound,
Thanks for the replies and links. I must admit looking forward to moving to an internal solution as I generally work on 2-3 projects at a time and could well manage on internal work drives and archive to firewire and DVD. My past problems with fw drive failure..most case or power supply related..make this a good looking option.
What is the advantage of "perpendicular recording" on some of the hard drives..I'm assuming it's seek time related but have not read up on it yet. Also faster is better i'm sure but is there a real world advantage of 10,000 rpm over 7200 rpm. I mostly do rock and blues. Low edit count little or no MIDI or virtual inst.
Thanks again
Bryan
Old 03-03-2007, 08:05 AM
7200 should be fine. I've used internal and external (SCSI and FW) Seagates for many years with no problems.
Old 03-04-2007, 07:02 AM
andrej770 andrej770 is offline
Though Seagates seem to be the favorite, LaCie's External drives use plain ole WD drives. Not sure what makes those externally enclosed drives any more reliable then the exact same naked drive. Hence, I have dual WD Caviar® SE16 500GB drives in my Dual 2.3GHz G5. I also have an external WD 1 Terabyte MyBook that has 1 USB port, 2 FW800 ports and 1 FW400 port on it. Works beatiful.
Mac 8 Core 6,1 - OSX 10.13.6 - 32GB RAM - Pro Tools 2018.10 - 8x8x8+8 ch DA Card (x2) - HD OMNI - ICON D-Control 32 - Sync I/O - Sonnet xMac Pro Server w/HDX x 2, Blackmagic Intensity Pro 4K
Protools 2018.10 HD Native in 1 project suite
Eristopher Music
Old 03-06-2007, 08:34 AM
c-tone c-tone is offline
I would also like to know more about perpendicular recording. Is there an advantage for Pro Tools users?
Also, does anyone see a significant difference when using 10K RPM SATA internal drives over the 7,200 RPM drives?
www.clifnorrell.com
Any benefit of 2nd internal drive for audio instead of firewire drive? JChance 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-15-2009 06:25 AM
Internal or Firewire audio drive? - 003 w/ Mac Pro salmonsound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-19-2008 04:25 AM
New Internal Audio Drive...Finally!!! fenderguy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-31-2007 10:48 AM
New internal audio drive crazyfoo' 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 01-26-2006 08:39 AM
Internal IDE Drive On G3 For Audio Les Carter 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-09-2000 12:42 AM
