Old 01-22-2006, 09:33 PM
Brain Digger Brain Digger is offline
Default blurry 2nd monitor
I am using the Radeon 9200 DVI-analog adapter for 2nd monitor but PTLE is a little blurry. If I switch the 2 cables, the other monitor is blurry --> therefore not the monitor. Both monitors are native 1280X1024 @ 60 Hz.
I have done a search and found very little info. Anyone have a fix for this .
XP Pro SP2
PTLE 7.4cs2-002R
Intel Core 2 Quad 2.4 GHz
K8V-SE Deluxe 4G DDR400
Radeon 9200SE-128M
Maxt 80G; WD 200G
CG8 200G SATA
Old 01-22-2006, 09:45 PM
Matt Whritenour Matt Whritenour is offline
Default Re: blurry 2nd monitor
maybe the cable?
once one of my monitors was blurried, and it just wasnt pluged in all the way
www.klarityrecordingstudios.com
Old 01-22-2006, 09:47 PM
Matt,
thanks for the quick reply. I will try, but even when I switch the two analogue cables from the analogu out to the DVI-analogue adapter, the other monitor becomes blurry. I will double check the adapter one more time and hope that it is something this simple. Can it be a 'bad' adapter?
cheers,
dave
XP Pro SP2
PTLE 7.4cs2-002R
Radeon 9200SE-128M
Maxt 80G; WD 200G
CG8 200G SATA
Old 01-23-2006, 02:11 AM
Tomy DeClerque Tomy DeClerque is offline
I have had the same problem with Radeon 9200 DVI out on analog adapter ...
tried everithing and nothing helped ... then I bought a new grafic card for 50% ( not radeon ) and it worked ... I was shure that was something wrong with my radeon ... but now ... it seems to be a common bug ...
tOMY
Old 01-23-2006, 04:03 AM
protein protein is offline
I have that card and my second monitor is blurry too. I just assumed it was the monitor... hmm...
http://bobbybloomfield.com
Old 01-23-2006, 07:29 AM
Are you running a CRT or an LCD? If its an LCD, it should be run at its recommended resolution(probably 1280x1024). LCD monitors are not as forgiving. Then again, it could be a bad cable, adapter or a card problem as mentioned. Can you borrow an LCD monitor with a DVI input to try?
Old 01-23-2006, 07:58 AM
vinark vinark is offline
I had the same problem with an unbranded radeon. Tried an asus and all blurriness went away. So that´s why the no name cards are cheaper , cheaper AD converter on the second output. If you lower the refresh rate and/or the resolution it gets better.
Old 01-23-2006, 10:10 AM
So which ASUS are you using successfully?
It must be the DVI output because switching the LCD monitors from cable to cable just changes where the blurriness is....I.e. switch cables and monitor 1 is now blurry instead of 2.
Re: try DVI input.....I will try to find a digital in monitor
Thanks all.......I guess I could simply take off my glasses and then both would be slightly blurry...
XP Pro SP2
PTLE 7.4cs2-002R
Radeon 9200SE-128M
Maxt 80G; WD 200G
CG8 200G SATA
Old 01-23-2006, 11:12 AM
Gary F Gary F is offline
Don't know if it helps, but within your graphics/display settings is the Advanced tab where you can access more parameters for your card and display options.
I use a Matrox but if I don't specify the exact parameters for each display monitor (ie resolution, bit depth and refresh rate) then running the display at a different resolution causes problems, blurring, slow movement ususual colours etc. I need to set the resolution, bit rate and refresh rate under Display options and then set them again within the Advanced settings of the Matrox control panel.
Is there an advanced setting which allows you to set these parameters?
Gary
Old 01-23-2006, 11:31 AM
I will have a look--I know I tried different refresh rates under the advanced tab without any effect.
XP Pro SP2
PTLE 7.4cs2-002R
Radeon 9200SE-128M
Maxt 80G; WD 200G
CG8 200G SATA
Can Studio Monitor Express & Transport act as digital monitor controller? briancares Artist Series 1 02-04-2014 05:23 AM
Anyone else noticing how blurry plugins are in 11? minister Pro Tools 11 3 01-14-2014 04:27 AM
Some Text In Pro Tools 7 is blurry. instro001 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 12-17-2005 01:44 AM
dual monitors - blurry screen and i'm not drunk Dave Gordon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 16 01-25-2005 10:39 AM
The boundaries are getting blurry klaatu Pro Tools TDM Systems (Mac) 3 01-27-2002 03:32 AM
