Old 01-24-2005, 07:15 PM
Dave Gordon Dave Gordon is offline
Default dual monitors - blurry screen and i\'m not drunk
hi all,
Is it normal for the second monitor (plugged into a DVI adapter) to have a slightly blurred picture, expecially for text?
I have the ATI RADEON 9200SE 128MB DDR 8X AGP DVI+CRT+TV. Text is definetely not as clear as the primary monitor, which has a crystal clear picture. They are both the same brand new sony monitors (17"LCD SDM-S73).
Could this be a driver issue? An installation issue?.......or just the way it is with dual monitors?
Thanks,
Dave
002 Rack
AMD Athlon 64 3200+
2x512MB memory
2X 120G WD
Old 01-24-2005, 07:31 PM
Dogcode Dogcode is offline
Default Re: dual monitors - blurry screen and i\'m not drunk
I have`nt had that problem with my system. Have you checked the settings for the second display?
PT 9
Control 24
003 Rack
Mac Pro 2.66 Quad
Adam A7
Waves Gold, VSeries
Pultec Bundle
URS, McDSP
Old 01-24-2005, 08:08 PM
keithl keithl is offline
hmmmm...now that you mention it, I also have a blurred 2nd monitor.
and I also have a Radeon....I will have to check out the settings.
Just always thought my new 1st monitor kicked that much more arse!
Old 01-24-2005, 08:13 PM
SimpleNatureSpirit SimpleNatureSpirit is offline
Make sure the monitor is set to it's native resolution.
Share the gift gifted to you
Old 01-24-2005, 08:25 PM
spkguitar's Avatar
My 9200SE functions similarly, but mine is a little different; I'm not using the DVI adapter. I have it hooked to two Dell 1900fp LCDs which have both analog and digital connections. One is hooked up digitally, and one via analog. The straight digital connection is much clearer than the analog. It doesn't bug me that much, but I have plans to upgrade to the Matrox dual dvi soon, hopefully solving my problem.
Old 01-24-2005, 10:59 PM
Screamer Screamer is offline
For those of you with DVI, check this out. It's a Clear Type Power Toy, and it really clears up the text. Also, be advise that some Dell LCDs are BGR and not RGB which can also affect clarity. This power toy can address that too.
Microsoft Typography Page
FYI, I'm running an ATi Radeon 9800XT with dual Dell 18" 1801-FPs....
Old 01-24-2005, 11:34 PM
Bastiaan Bastiaan is offline
It also could be a good idea to click the "auto" button on the monitor to get it properly alligned or something like that...
What's that?
- That's the machine that goes "pling".
Bastiaan
Old 01-25-2005, 04:46 AM
I am running with the DVI adapter...
Old 01-25-2005, 06:54 AM
daustin777 daustin777 is offline
Are you using the same cable going to each monitor? Cables make a big difference with monitors.
David Austin
p4 3ghz, PT 6.4, XP, Digi002r, AMT8, Mackie Control
Old 01-25-2005, 07:25 AM
Eddie D Eddie D is offline
^5's fellas,
9200se here also,,, running dual monitors and 1 of mine is not blurry, but not as bright. There is a slightly different shade of coloring, white backgrounds have a milky color on one and on the other monitor its so much brighter, cleaner. (analog vs digital I would assume) before reading this I figured I had a bum monitor or QC was not so good. (2 dell 1901fp 19" lcd's) Its not too noticable, most people are just surprised because your running dual 19 lcd's. Again here its not a big enough deal to really worry about unless it gets worse.
Eddie
Who Ever said this would be Easy!!!
www.myspace.com/sightthrusound
Wide screen monitors & pro tools? 540s 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 08-05-2007 03:44 PM
Got a little drunk, thought I try recording some cary chilton 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-17-2006 01:45 PM
Anybody using plasma televsion screen for monitors losttimestudios Pro Tools TDM Systems (Mac) 7 10-06-2005 07:58 AM
O.T. Anyone using touch screen LCD monitors 4 PT? mac goD 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-14-2005 01:03 PM
Two DVI/flat screen monitors nz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-03-2001 08:36 AM
