Old 04-22-2022, 07:11 AM
sw rec sw rec is online now
Default Re: Windows + Pro Tools sound with ASIO4ALL?
Focusrite Scarlett interfaces have served me well (as a SECONDARY interface for Windows-related sounds…using a UA Apollo 8 for my PT interface.) Just bear in mind that trying to get ANY interface to “share” Windows sounds and PT is asking for trouble.
Old 04-22-2022, 07:30 AM
On my last bigger system, I needed optical SPDIF for computer audio(my HP Z820 didn't have it) to feed my monitor/source switcher(Presonus central Station). I got a Behringer USB to SPDIF adapter for around $35 and it worked great.
Old 04-22-2022, 11:20 AM
The Weed's Avatar
The Weed The Weed is offline
Get an interface with 4 or more I/O - Audient Evo 8 or MOTU M4 come to mind (bonus with either - they have Loopback). Use a mini stereo to two quarter jack TRS adapter cable to bring signal from your onboard soundcard into the interface. Put up a stereo track in Pro Tools and assign its input to that I/O. Put the track in Input Only if you just want to hear it and Record if you want to record the signal. Or, as albee mentioned, use an Optical cable if your onboard soundcard and interface have that connection.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 04-24-2022, 01:40 AM
kol12 kol12 is offline
I really like the look of the UA Volt 2 and it reviews well. Is anyone familiar with the Volt 2? Does a USB bus powered interface put more load on the CPU than a DC powered interface?
Old 04-26-2022, 07:14 AM
junkgear's Avatar
junkgear junkgear is offline
No, powering a USB device via the port vs an external adapter has no affect on CPU load.
Will
System Details
Old 04-27-2022, 02:08 AM
Just coming back to this. Other than recording inputs on an audio interface does an audio interface actually do anything more than my internal SoundBlaster soundcard?
Old 04-27-2022, 02:41 AM
I replied earlier with a answer listing lots of stuff the might be important to consider when buying an interface. How many of the things I mentioned are done by a Soundblaster card? You understood everything I listed? If not and you want to learn about interfaces go read up on stuff, google words, read a few owners manuals for some interfaces etc. Just please stop asking question after question on DUC without seeming to do much of you own work/learning. And especially please stop repeating yourself and re-asking questions already answered.
You can look over online dealers interface sections and if you have questions contact a sales rep. And most importantly buy something to get started with and start doing stuff and learning. Asking question after question on DUC about learning stuff and getting started is not helping if you don't actually get started and like all of us when we got started... you likely won't know enough right now to even know what questions to ask, or really able to work out what gear you really need etc. You solve that by just getting started.
Sounds like you are on a somewhat limited budget, and you want to loopback windows PC output so get a 2 mic and 2 line input Focusrite Scarlett 4i4 interface or something else close to that (with a vendor supplied ASIO driver). Just get going.
Old 12-02-2023, 08:47 AM
Cagney Cagney is offline
Just to add to this, voicemeter instead of asio4all has always worked for me on pc to allow both protools and windows sounds at the same time.
https://vb-audio.com/Voicemeeter/index.htm
No Sound, 2019.6, Windows, ASIO4ALL beginnerprotool Windows 3 10-13-2019 06:27 PM
BSOD Windows 10 ASIO4ALL djbigkraq FireWire & USB Audio Interfaces (Win) 0 03-28-2016 08:12 PM
No Sound Pro Tools HP Laptop asio4all malmalibu Windows 14 11-25-2013 04:47 PM
Pro Tools 10 asio4all HP Pavilion no sound malmalibu Pro Tools 10 1 08-29-2013 06:22 PM
Pro Tools 10 & ASIO4ALL on a Mac running Windows aj88keys Pro Tools 10 1 01-09-2012 01:39 AM
