Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
Old 01-17-2025, 02:32 PM
shawnhonsberger's Avatar
shawnhonsberger shawnhonsberger is offline
Default Copy Trims and Delays from Output Group to Another in Profile?
I see that you can copy all eq filters from one channel to another in another output group, which is super handy. Can you also copy delays and trims?
I'm trying to replicate an output group from scratch, but I was curious if there was any shortcut to copying all delays and trims or if everything needs to be done manually - clicking back and forth and manually matching.
Thanks!
Be safe and well,
Shawn
Argyle Street on Apple Music
System: Mac Studio M2 Ultra 24 Core CPU, 60 Core GPU, 192GB Unified Memory, 4 TB SSD, Studio Display, iPad Pro M2, I/O + Control: Avid MTRX Studio, Avid Thunderbolt 3 Module (TB3 Native), MRTL/PRTL: (96k) 1.2ms/.9ms at 32 samples, 1.8ms/1.6ms at 64 samples, (48k) 2.3ms/1.8ms at 32 samples, 3.6ms/3.1ms at 64 samples, Avid S1 EUCON Controller, Elgato Stream Deck XL, Software: Avid Pro Tools Ultimate Perpetual 2025.6, Avid EUCON 2025.6, Avid Control 2025.6, Avid MTRX Studio Firmware 1.1.5.1, Avid DADman 5.8.1.6, Avid DADTBDriver CoreAudio 1.2.2, Dolby Atmos Renderer 5.3.1, macOS 15.5, Logic Pro 11.2, Ableton Live 12.2.1, SoundID Reference for Multichannel 5.12.1, SoundFlow 5.10.6, Scheps MOMDeck, Monitors: (9.1.4) Kali IN-8 V2 (9), Kali WS-12 V2 (1), Kali IN-5 (4)
Old 01-18-2025, 04:41 AM
creativecontrol's Avatar
Default Re: Copy Trims and Delays from Output Group to Another in Profile?
No, but you can use the Import from Profile function (which is similar to Import Session Data in Pro Tools) to bring bits into your active monitor profile. Just bring in the desired output set a few times - which will already contain the trims and delays, then modify them appropriately.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 01-18-2025, 08:11 PM
Thank you, Jeff!
Be safe and well,
Shawn
Master vs Cue in DADman Monitor Profile Group Mode? ric982 Pro Tools | MTRX & MTRX Studio 7 11-16-2023 05:23 PM
192 I/O Output trims: amount of amplification Mark Ziebarth Pro Tools TDM Systems (Mac) 6 01-08-2014 03:18 AM
HD Omni Monitor Controller/Output Trims Jantzen Pro Tools HDX & HD Native Systems (Mac) 0 08-03-2013 08:57 AM
192 I/O - Analog output trims not working? trian Pro Tools TDM Systems (Mac) 0 08-12-2009 01:46 PM
Problems with Output trims on the 192 I/O DigiPanzer Pro Tools TDM Systems (Mac) 1 06-19-2002 10:57 AM
