Old 12-23-2005, 05:32 PM
wangell wangell is offline
Default Running LE without 002r hardware attached ?
I've searched and have been unable to find this. How do I get protools to run without the hardware attached? The 002r is in a double-wide rack case, but we want to listen/edit each nights recording on our bus.
Thanks,
Old 12-23-2005, 06:08 PM
Default Re: Running LE without 002r hardware attached ?
It can't be done.
Quad 2.5 G5, 4.5G RAM
Old 12-23-2005, 06:09 PM
Slim Shady Slim Shady is offline
You can pick up an Mbox to keep in the bus, a little smaller than the 002r. Some sort of LE hardware must be attached for PTLE to run.
Old 12-24-2005, 06:56 AM
Ouch! Thanks though. I like protools, but I don't want to lug a big piece of hardware around with my laptop just to make it work (and this would be a real pain on a plane) and I ain't too thrilled with shelling out another $500 just to get something to make the software work. Guess it's back to Cubase or Vegas - not great choices, but at least I can use them.
Thanks again,
Old 12-24-2005, 08:07 AM
K-Man K-Man is offline
Actually, the M-Audio transit is qualified for Pro Tools M-Powered 7. That little box is just a bit smaller than a pack of cigarettes. Give that a try, if you're looking for portability.
-K
Apple Mac Pro 3.0 8C
8GB RAM
Digi002R
Dynaudio BM5a Monitors
Mac OS X 10.4.10
PT|LE 7.3.1cs4
CoreAudio 7
Old 12-24-2005, 08:15 AM
OK, if I pay $800 for a Firewire 1814 and M-Powered I CAN run it seperately on my laptop, but if I pay $400 more for a 002R with PTLE I CAN'T run it seperately?
From a software standpoint I think the only major diff is lack of control surface support in M-Powered. From a hardware standpoint there are some pluses and minuses on each side, but from what I can tell for basic analog IO for recording the two solutions are about equal except for a diff in the pre's (not sure if there is a diff and which way it leans).
Somewhere along the way of my life I got the idea of pay-more, get-more. Not pay-more, get-less. Am I missing something?
Thanks,
Old 12-24-2005, 09:07 AM
M-Powered doesn't lack control surface support, and I'm pretty sure it can't be run unless supported M-Audio hardware is connected.
Old 12-24-2005, 09:19 AM
According to the information on the digi site, including their comparison chart of LE vs MP, MP does not include support for control surfaces while LE does. I am pretty certain MP WILL run as long as an ilok is present (ilok is included with software) and from everything I've been able to learn, LE will NOT run without an 002 or Mbox.
If I'm missing something please let me know.
EDIT: I was wrong and just looking at the Control24. MP does support the Control8.
Old 12-24-2005, 02:14 PM
DJ Insomaniac DJ Insomaniac is offline
Even if it could run without the M-Audio hardware attached, you wouldn't get any sound. It'd need the M-Audio box to output through.
Although i'm really sure that you need to have the M-Audio stuff attached for it to work.
Sam Ejnes
Re-recording Mixer
samejnes.com | IMDb | Analog Jitter
Old 12-24-2005, 03:21 PM
The idea would be to edit using IEM's from the laptops earphone port. You ain't gonna do alot of intricate level setting or eq'ing, but I can do alot of cut&paste as well as critique concert tracks. I've been doing this with Vegas for about 2 or 3 years now. Vegas is OK for audio, but I generally like Protools better when I've used it.
Do I need the Hardware attached to use ProTools SE? lifeisacabaret Pro Tools SE and Essential (Mac) 0 10-21-2012 01:30 PM
PT9 without hardware attached? SNAPPER Windows 8 02-11-2011 12:52 PM
Using Pro Tools with no hardware attached... chris002r 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 33 06-03-2005 11:33 AM
Running Sonar4 in 002R Relakst 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-27-2005 09:45 AM
002R running with 5.3.2?? El Gato 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 10-25-2004 08:29 PM
