Old 10-09-2017, 01:53 AM
Nyholm Nyholm is offline
Default Synchronize by waveform (like the Premiere Pro feature)
Hey guys.
I was wondering, if there were any plug-ins or features for Pro Tools that
could synchronise 2 audio files by waveform like you can in Premiere Pro.
E.g I have recorded sound through my camera mic (which sounds like crap)
and a small recorder which haven't been synced by timecode.
I have briefly had my hands on Titan 4 but it seemed to be for a quite outdated
workflow or maybe I just thought it was too much work for what i actually
wanted it to do.
Cheers
Old 10-09-2017, 02:22 AM
jchan jchan is offline
Default Re: Synchronize by waveform (like the Premiere Pro feature)
Never thought of, would be a genius feature but nothing I've come across other than level the clips as equally as possible, phase shift one channel and manually nudge until its as low as possible in volume..
Old 10-09-2017, 02:26 AM
Stig Eliassen's Avatar
Should be pretty easy to sync the two files using a transient.
- identify a sync point by tab-to-transient (Cmd+, on a Mac/ Ctrl+, on a PC) on the audio from the recorder
- tab-to-transient on the same spot from the camera audio
- Ctrl+Shift+click (Mac) the audio clip from the recorder with the Grabber tool to snap the sync point to the cursor
You can also do this visually by gradually zooming in, and gradually dragging/nudging the audio from the recorder against the cam audio.
Old 10-09-2017, 03:01 AM
I sync visually, if there is no proper sync available. The sync doesn't need to be very sample accurate... say you have 48kHz audio and 25fps video, it means one video frame is 1920 samples. If you don't get lip sync you haven't even tried
Old 10-09-2017, 09:34 AM
The Weed's Avatar
The Weed The Weed is offline
Or just use the front of a word. Zoom in and place a sync point on one track, then do the same with the same word on the other. Then, in Slip Mode, tab the cursor to one sync point and Windows Key+Shift+Click on the other clip and the sync points will line up.
I do this all the time when using a Playlist for QC and the original track has moved because of editing and I need to line both back up again past the edit.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 10-10-2017, 06:39 AM
Thanks for the feedback guys. A lot of great workflows.
I just had a case while doing a documentary in which they sent only the cam
mic in the AAF. I then noticed that the person being interviewed that a lav mic on her.
Later they sent the whole interview from the recorder but with no TC.
The problem with visual sync or tab to transient in this case was that the
sound files in the AAF had only a couple of seconds of handles and the whole
interview was about 20 minutes. So there was quite a bit of work in just
finding out where the AAF files would fit in the recorder recording
BUT! Premiere Pro does a great work in doing that. Sometimes it's a couple of frames off, give or take, but it's a timesaver.
Anyhow thanks again guys, i guess we'll have to wait for a plugin for that
Cheers
Old 10-10-2017, 08:07 AM
john1192 john1192 is offline
Cheers
maybe Synchro arts Vocalign plugin .. or Waves In Phase, of if using UAD Little Labs IBP plugins .. some of these might do what you need ...
and yes Titan is old ...
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 10-10-2017, 09:34 AM
conleec conleec is offline
I haven't tried it in Pro Tools, but have used Plural Eyes to syncronize dailies with camera footage in Media Composer. There's a free trial, I think.
https://www.redgiant.com/products/pluraleyes/
Good luck.
Chris Conlee
PTHD 2018.1, Behringer FCA610, Blackmagic Intensity Pro (driver v10.8.2)
Mac OS 10.13.2, 2009 Mac Pro, 32Gb RAM
Old 10-10-2017, 11:29 AM
Good luck.
is this an AAX plugin ?? i took a look at the link but do not see any programs but Avid and Adobe that pluraleyes will work within .. curious if PT would see it as well !!!
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 10-10-2017, 12:01 PM
Dan IceWood Dan IceWood is offline
Why not just import into premier , sync and then export to audio to import to PT
will 9 synchronize with, say a MOTU DTP Craig F Pro Tools 9 2 11-11-2010 07:53 PM
Synchronize the venue and Protools? jjmanton VENUE Live Sound Systems 4 02-17-2008 10:38 PM
how to synchronize PT and other solftware? march 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-25-2006 08:09 PM
How do I synchronize a couple of Digi002R? Mariuco 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 08-09-2004 10:49 PM
ilok wont synchronize villagesound Pro Tools TDM Systems (Mac) 1 05-18-2004 12:15 PM
