Just curious how people are inputing the signal from an electric guitar (humbucker pickups)into PTLE via Digi 001. I'm thinking of picking up Amplitude, BF Sans Amp, etc., or maybe an external modeller and wondering what other costs I would incur w/ Amplitude. Have people have good enough signal to "drive" Amplitude going direct into 001 (I would assume channels 1 or 2 using the gain)? Or would a good direct box be a necessary investment?
If I'm not actually mic-ing an amp, I run a POD 2.0 into a JoeMeek British channel and then into PT. Works great.
Don't know about Amplitube, since I bought my PT two weeks before that promotion started (!) Paul
Dell Pentium 4 3.0GHz, 800MHz FSB 1GB pc3200 DDR 60 GB Glyph FireWire Digi 001, PT LE 6.1.1 - Screw 6.4! |
I've gone straight into the 001 through the 1/4" on the front with stock PRS pick-ups, and used Amplitube and BFD's Sans Amp and it sounds great. I have also gone the DI, preamp, to the 001 way and that was good also. I think just straight in gives me fine results and anything else is subjective to taste. An active DI can save the day sometimes, especially if you have weak output pick-ups.
https://www.thirdeyerecording.com/ System Details: Avid HDX x 2: HP Z6 G4 Dual 16-Core Intel Xeon Gold 6226R 2.90 GHz, Lynx Aurora 16 LTHD x 6, Digidesign 192 i/o x 2, Pro Tools Ultimate 2024.6, D Command w/ Xmon |
Emulate complete guitar signal path: Comp -> Amp -> Reverb | BrainSaladXero | Virtual Instruments | 7 | 11-30-2007 03:28 AM |
Signal Path (for an 001) | Cavet Your Eruptor | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 07-28-2006 12:55 PM |
Signal Path | bluesna | Tips & Tricks | 0 | 01-10-2005 01:02 AM |
signal path plug-in | nightshade crisis | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-09-2002 11:31 PM |
C 24 signal path (does this look right?) | sidereal | ProControl, Control|24, Command|8 | 3 | 03-19-2001 01:12 AM |
