Old 09-19-2003, 09:39 PM
Howardk Howardk is offline
Default >> HD3 crashing OS9
I am in the middle of mixing a project with an out-of-town guest and my ProTools rig has decided to start crashing over the last couple of days. . . it is doing so about once every 30-60 minutes. No pattern. . . . I just get the fingers tapping forever and have to Control/Apple/Esc to try and get out. Sometimes it happens while it is playing but keeps playing or sometimes while at rest. . . no obvious triggers. Digitest says my HD Core card has a clock problem, but it has said that since the day I bought the system. The rest of the Porcess cards test OK. It is doing this on the last four session we have been workin at. . . This is killing us. . . IDEAS!
G4 - 933 Mhz w/ 1GB RAM
OS 9.2.2
ATTO PCI UL2D
HD3
ProTools 5.3.1
...for system configuration info see my profile
(Click on member name)
Old 09-19-2003, 10:00 PM
Tweakhead Tweakhead is offline
Default Re: >> HD3 crashing OS9
Just the usual stuff.
1. Trash Pro Tools prefs
2. Trash DAE prefs
3. Trash DigiSetup
4. ZAP PRAM (Hold Option+Command+P+R) during startup several times.
5. Reseat PCI Cards and Digi cables.
6. Disconnect ALL SCSI devices, USB and Firewire peripherals.
7. Re-Install Pro Tools
8. Run an anti-virus program
9. Create a new session.
10. Test RAM
11. Reinstall OS9
12. Call Digi Tech Support.
13. Rent a system to get you thru your session
Not necessarily in that order. Try the simplest things first.
Old 09-19-2003, 10:09 PM
Thanks. . . I especially like # 13.
Old 09-20-2003, 10:13 AM
kurt's Avatar
kurt kurt is offline
How hot is your G4 running? Point an table fan on it.
MBP early 2011. Apple MacPro 5.1 12Core ”Westmere”. DeckLink HD Extreme 3D+. OS X10.10.5
PTN|10-11. PTN|HD|10-11-12. 16 x 16 HD I/O - 16 x 16 192 I/O Lots of gear.
http://www.mmvstudios.com
Old 09-20-2003, 02:16 PM
koko koko is offline
....aaaaahahah that's a good one, except i've seen it done on a 9600/MIX rig...you have to open the side to get a proper airstream onto the cpu and disks. It worked !! Without that the 9600 would crash every so often.
Post Meridian Productions
Old 09-22-2003, 10:22 AM
tnie tnie is offline
maybe it's time upgrade?
Old 09-24-2003, 09:18 PM
Actually upgrading is what got me into this mess in the first place. My Mix5 system on a 9600 was rock solid. . . My HD system has never been and i have reinstalled from scratch 3 times over the last year and it was pretty stable over the last 3 months (1 crash/day). However now it is almost unusable. Latest problem is a session will not load and we get the message "You do not have enough DAE memory" I currently have 756MB with 425MB allocated to ProTools. I have tried everything I know of and am still crashing every 30-60 minutes and in all the sessions.
I am going to try a different HD core card tomorrow. Any other Ideas?
Old 09-24-2003, 09:53 PM
Lee Blaske Lee Blaske is offline
Do you have a different computer to test things on? You could be experiencing subtle or not-so-subtle computer problems. There seems to be a rash of bad PCI slots these days - possibly from people being too rough while inserting or removing cards. You might also have a bad memory slot, or bad RAM.
Also, you might want to try removing the ATTO card and running with just internal ATA drives, or Firewire drives.
Lee Blaske
Old 09-25-2003, 04:10 AM
kurt's Avatar
How much have you assigned to DAE? & what is DAE buffer size?
8.0.5 crashing barra 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-24-2011 05:20 PM
8.0.3 keeps crashing davidreidlive 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 01-18-2010 02:47 AM
8.03 keeps crashing- HELP ! barlevy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-23-2009 11:48 AM
Mac Pro Crashing With PT8 RussUK 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 11-10-2009 06:48 PM
M Box - G4 ...Just keeps crashing and crashing... nessein 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-11-2003 09:59 PM
