Old 11-08-2000, 02:06 PM
blncmn blncmn is offline
Default selecting digi as Sound Manager output (or) previewing peak plug ins
I am trying to preview premiere format plugins in peak. or get any sound manager output through the 001 at all. I cannot get sound ou through the digi hardware in any app that uses sound manager (soundapp, T Rax)
When I select digi as the sound out port, these apps freeze or give me error codes.
also peak 2.5.2 seems to lose its ASIO connection once in a awhile and has to be reminded that it is Direct io.
any ideas? thanks in advance..
Old 11-09-2000, 03:11 PM
Jeff D. Jeff D. is offline
Default Re: selecting digi as Sound Manager output (or) previewing peak plug ins
Blnc,
I've had good luck with both Peak and Spark and the 001. Here's what you do:
1. Put "Digidesign Output Driver" into your extensions folder & restart
2. Find the "Sound" conrol panel (not "monitors and sound", but "Sound". It's on the PL Le CD. Drag it to the Control Panels folder
3. Open the "Sound" control panel and select "Sound Out = Digidesign".
4. Open Peak and select "Sound Output = ASIO". Once ASIO is open, select Direct Connect, set up the 001's I/O as you like, and then check the "deactivate for previewing" box. Uncheck the "active in background box" (can cause Peak to forget about ASIO).
5. Don't mess with the Digidesign Control Panel - may cause Peak to forget about ASIO.
Even with this setup I get a few glitches (noise bursts when re-winding a playlist with Waves plug-ins, noise bursts when dealing with playlists and 24bit I/O)... for those activities I switch from "ASIO" to "digidesign" or "built in:" and everything works fine (except that it doesn't sound as good as ASIO since you are listen through Sound Mangler).
All of this works for me on OS 8.5 and 8.6.
Good luck,
Jeff D.
www.jephthastudios.com
Digi Audiocore manager - no sound Arnolievens Pro Tools TDM Systems (Mac) 2 09-22-2011 02:16 AM
How about an Apple Sound Manager RTAS plug-in? Steve MacMillan Pro Tools TDM Systems (Mac) 2 11-04-2005 12:07 PM
Digi 001 and sound manager? osclinear 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 05-02-2003 11:32 AM
PT LE via Sound Manager output ru2b12 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-20-2002 09:17 AM
Output Driver/Sound manager savage Pro Tools TDM Systems (Mac) 10 08-16-2001 09:22 AM
