Old 12-20-2012, 02:35 AM
yamahadrums yamahadrums is offline
Default Pro Tools 10 crashes on Export Clips As Files.
It just crashes. Anyone?
MacPro 2.66GHz 8Gb RAM Mac OS X 10.7.5, Pro Tools 10.3.3, DIGI 003 Factory, LogicPro 9.1.8, Tascam FW-1884, Adam A7, Roland TD-20, Yamaha SY-99, Audiotechnica ATH-M50.
Old 12-20-2012, 02:53 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Pro Tools 10 crashes on Export Clips As Files.
Is it just the one session or are all your session having this problem?
If you select just one clip file and export does it do it?
what bit rate and frequency are you using?
What bit rate and frequency are you exporting to?
Chris
Producer, Engineer,
www.ukmastering.com
Old 12-20-2012, 02:56 AM
Haven't tried with another session yet.
No matter if I select 1 or multiple clips-it just crashes.
I export the same bitrate and freq as the original files in the project.
Old 12-27-2012, 11:51 AM
Bump! Pro Tools HD 10 keeps crashing on export. I do not own the HD version, but I am testing a free 1 month trial, which expires on January 8-th. Could it be the HD causes these crashes?
Changed from Multiple mono to Interleaved fixed it.
Title/Name confusion with "export clips as files" stargazer macOS 0 03-02-2014 11:05 PM
Export Midi Clips txshonk Pro Tools 10 2 04-06-2013 08:28 PM
Export Clips as Files... (to mono) Ryan Young macOS 4 06-06-2012 12:41 AM
Clip Gain and Export Clips as files Farmer Dave macOS 2 03-18-2012 10:48 AM
AV4.0 ADR Group Clips export alex weber Post - Surround - Video 1 06-23-2010 06:05 AM
