I've been getting this pretty often these past few weeks and its getting annoying to be honest.
the message tells me CPU OVERLOAD Must increase H/W Buffer playback engine or disable plugins or something in the looks of that and i can't even playback my recordings i've got a few plugins but nothing too extreme, a few Air plugins and Smack on a few tracks. i've disabled my instrument tracks while recording and it keeps popping back up and stopping my recording session or playback session after a few seconds. i use an macbook pro 17'' 2.5 Ghz Intel core Duo, 4 G RAM ,with an Mbox 2 Pro and recording to a LaCie usb 2.0 1To Harddrive running PTLE 8.04 on Mac OSX 10.6.4 should i get a mac pro to solve the issue or is there a way to get more power from my CPU. (i've disabled Dashboard BTW) Any help will be very helpful.
- Frank MBP 17'', 10.6.4, 4GB Ram, MBox 2 Pro, 1TB LaCie BigDisk, PT LE 8.04 |
USB drives are not supported, but as mentioned do post your buffer settings.
Lincoln Mitchell www.studiofifty.net Mac Pro 2.66 Ghz Quad, 10.6.6, 12GB Ram, PT9, Logic 9, Kontakt, East West, VSL, Waves, Sound Toys, IK Multimedia RME FF UC, Focusrite Octopre mkii, UA LA 610 mkii, MC Transport, Yamaha HS80M, Lauten, AKG, Sure, Blue |
My opinion:
Cut the USB drive and replace with firewire... |
wait, are you running protools off of your external usb drive?
2.66GHz Quad-Core Intel Xeon 6 GB SDRAM 3 1 TB WD Caviar Black Hard Drives Eleven Rack, Axiom 61 |
Just to be clear, you shouldn't be recording to a usb drive, and the actual protools program should be installed on your main system drive, with only the audio recording to a proper firewire drive.
nts 7 gave important advice..... mhelm asked an important question...
![]() Quote:
SOrry for the late reply, i've been out of town andf had a million things to do. PLAYBACK SETTINGS H/W Buffer size: 1024 Host processors : 2 (2 is the max i have) CPU Usage limit: 90% DAE Playback Buffer Size: 3000ms Level 4 cache size : Large Plug-in Streaming Buffer size: 1000 ms Level 8 RECORDING SETTINGS H/W Buffer size: 64 Host processors : 2 (2 is the max i have) CPU Usage limit: 90% DAE Playback Buffer Size: Level 0 cache size : minimum Plug-in Streaming Buffer size: 60 ms Level 0 BTW i'm running protools on my system drive and recording to my lacie big disk thanks all
Ok, A few things.
1. Is your Lacie drive connected to your computer using USB? That's what it says in your OP. USB is NOT supported. Yes sometimes they work, but it might cause problems. 2. I'm not sure about external drives, but internal drives should have a 32 MB Cache. This one has a 16 MB Cache. 3. Raid drives are NOT supported. 4. Try setting only one core set to 99%. 5. Yes get a Mac Pro. They're awesome.
my lacie 1TB Big Disk is 7200 RPM and i plugged it firewire.
dunno about the cache though. I'll try the cpu settings thanks
Fwiw, the cache size was referring to the hard drive.
constant CPU error overload!!! | clintusmaximus | macOS | 1 | 12-06-2012 04:17 PM |
Constant CPU Overload and DAE 35 Error | AlissaAudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-20-2012 03:49 PM |
Mbox 2: record enable constant meter overload?? | msnorthc@comcast.net | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-21-2010 11:40 AM |
Constant CPU overload errors!!! | maxxdog | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 07-09-2010 10:27 PM |
Constant CPU Overload!!! Really annoying!! Help!! | listenhard | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 10-12-2009 03:31 AM |
