Old 11-08-2021, 05:29 AM
o-matic o-matic is offline
Default Swapping, v21.10
Hey all,
I've been updating to 2021.10 and try the new swap feature which should be very useful to my workflow.
But I'm experiencing a strange behaviour in the soft key displays.
After populating the second layer, the Swap button light up in blue and I can then swap globally between these 2 layers. But then the active Layout button (soft key) switches off and as I press it again (or any of the soft keys of any other layouts), a new layout named "Backup..." appears, increasing the number off layout every time...
I own a S6 M10 and couldn't swap locally, btw...
I can't figure out what I'm doing wrong...
Old 11-08-2021, 09:03 AM
creativecontrol's Avatar
Default Re: Swapping, v21.10
Greetings,
It sounds like you have Settings > User > Auto-Save Changed Layout on Recall Mode enabled - which has a few different options. If you recall a Layout (regardless of Swap layers or not) and make changes, it can automatically save the modified Layout to a new slot in your list. You can completely disable this behavior by setting the pref to OFF.
Regarding Swap Layers, ensure that after using the global Swap switch on the MTM to add or tweak additional layers, you leave on the layer you want to recall on and always press Store to save the changes while you are in Assign mode. This is especially important if you've defeated the auto-saving above.
best,
Jeff
Jeff Komar
Solutions Specialist, Pro Audio
S6 FAQ
Old 11-09-2021, 12:35 AM
Yes ! Great !
Thanks, Jeff !
Swapping gpu's? jjsoundoc Post - Surround - Video 3 09-28-2020 05:56 AM
AutoHotkey for key swapping SomeDumbHuman Windows 1 07-22-2016 03:46 PM
Swapping out PC Soulsanctu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-07-2005 07:12 PM
Hot swapping the 001 QuikDraw 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 01-06-2005 02:22 PM
Swapping Mobo & CPU?! xeetstreet 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-25-2004 01:03 PM
