PT 9 Export Track Issue
Hello, I have an iMAC, 2.66ghz, 2g Ram, PT 9, M-Audio Firewire 1814.
I'm having the darndest time exporting tracks. I will record tracks, edit the regions, consolidate, and then export. What happens is I get many oddly named audio files, most of which are extremely small-sized files, and only one of those files is the full exported track. The rest are small clips of that track and are completely useless. Why do I export a consolidated track and end up with up to 10 useless small tracks I have to sort through until I find the exact audio file that has all recorded material? Thanks |
Re: PT 9 Export Track Issue
It sounds like you might be selecting everything in the Regions list when you export. Select only the consolidated regions. Once all tracks are consolidated, that can be done quickly by opening the Regions bin, clicking in a ruler in the Edit Window, then typing the Select All command (Cmnd-A). Then use the Export Regions as Files command in the Regions Bin menu (Shift-Cmnd-K). This is needed because consolidating doesn't delete the files that existed prior to consolidation, it just adds the consolidated files to the session. The exported files will have the same name as the regions have in the session. You can rename them in the session by selecting them and typing Shift-Cmnd-R.
David J. Finnamore PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB |
Export Session Info as Text issue | Francois GOA | macOS | 1 | 10-18-2013 10:41 AM |
Screen Flashes during export issue. | realizment | Windows | 2 | 10-12-2013 01:35 AM |
Pro Tools Export / Region List Issue | drewsmith | Pro Tools 10 | 0 | 03-09-2012 05:13 AM |
MP3 Export (Music Production Toolkit 2) - authorisation issue | NZDingo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-29-2009 03:21 AM |
Mp3 Export option issue; can anyone else test this? | RBaker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-06-2008 07:28 AM |
