Old 06-21-2021, 04:09 PM
James H James H is offline
Default My Audio speed is wrong. Sample rate different than session
my partner is doing the recording in audacity and I am doing the editing and mastering in pro tools. When I load the file from audacity into protools, off of the google drive we share, it sounds like the sample rate is faster. I get an error that says "one or more of the files you have selected to add have different sample rates than the session. these files will play back at the wrong speed do you want to continue?"
My partner is recording at 44.1 K Hz and my session also says 44.1 K Hz. Can anyone tell me what they think the issue could be?
Old 06-21-2021, 04:31 PM
climber climber is offline
Default Re: My Audio speed is wrong. Sample rate different than session
Sounds like your interface is at a different sample rate.
Al Hospers
bassist, vocal, composer, engineer
https://www.youtube.com/channel/UCCw...ogfR_7Q/videos
PT2023.12, OS X Monterey, Late 2013 MacPro, 6 core, 64 GB RAM, Orion Studio, Slate Raven MTi2, ISA428, ADL600, Distressor, Grace 501, Dimedio, Obsidian, One LA, BAC500, Harrison 32 EQ, UAD2 OCTO, Focal 6 be, Auratones...
Old 06-21-2021, 06:52 PM
More to consider:
1-is anything connected to the interface via digital? If the extra device is at the wrong sample rate, your entire session might be clocked incorrectly.
2-open Preferences and make sure you have it set to Automatically Copy Audio on Import and to covert sample rate to session sample rate on import.
To fix it, create a blank session at 48Kand import the audio(or session data) but set it to NOT apply SRC(sample rate conversion). Given you have a 44.1K session that sounds fast, its likely being clocked at 48K(either now, or when it was recorded)
Old 06-21-2021, 11:21 PM
JFreak JFreak is online now
Hi, welcome to the community.
What ^^ Dave said, and the sample rate mismatch may very well be on your partner's end not yours, so just try to fix it by importing to "wrong" sampling rate session without SRC.
Old 06-22-2021, 01:09 AM
roundbadge roundbadge is offline
Are you dragging and dropping the files into the session or using the import audio mode?
Audio file had the wrong sample rate when video bounced speshow5180 Pro Tools 2020 2 03-02-2021 01:25 AM
One session playing back audio at wrong speed vitolanzafame Pro Tools 2018 1 10-02-2018 09:29 AM
Import session data sample rate conversion also stetches audio? nick133 Windows 1 07-18-2012 10:30 AM
help..session at wrong sample rate!!!!!!! ejsongs Pro Tools TDM Systems (Mac) 1 04-21-2006 05:21 AM
wrong sample rate JBT24 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 06-22-2005 05:18 PM
