Old 07-29-2009, 10:08 AM
LucidMJW LucidMJW is offline
Default SRS Circle Surround Encode/Decode Plug
Does anyone else here have experience using these plug-ins to make LtRts? I've been using them to create LtRt from 5.1 mixes and the steering issues have been driving me crazy. Dialog (or other center channel audio) gets dropped from C and put into L/R constantly, especially if there is other program (music / sfx) that is louder than the dialog. I've been doing LtRt mixes using a bounced 5.1 mix. I have the encoder and decoder on the master fader, and I split the 5.1 track to mono so I can adjust gain to ensure C channel audio stays in C. This method works to some extent, but in the process, changes the dynamics of the mix way too much for my taste. At the end of the day, I either have a decoded LCRS where the center channel is too loud or C channel audio shifting between C and L/R, sometimes multiple times a second. If there is anyone who can let me know of a better way to mix/monitor an LtRt mix please leave a post. Thanks!
Old 07-29-2009, 12:51 PM
TVPostSound's Avatar
TVPostSound TVPostSound is offline
Default Re: SRS Circle Surround Encode/Decode Plug
SRS Circle TDM is DEAD.
It has decode issues with PT 7.4 and up. The company stopped selling, and supporting it.
Old 07-29-2009, 01:33 PM
quadraphonics quadraphonics is offline
A bit of Dialogue divergence into the Left and Right of a decoded LCRS is common. It is a by-product of creating the Dolby Stereo matrix. Also remember that you can only really be panning one thing at a time on a Stereo mix, otherwise you might run into issues with the folddown.
Now that SRS is no longer supporting your product, there are a few others you might want to look at. The Dolby Surround tool works well. Both Minnetonka and Neyrinck make audio suite plug ins that will matrix a 5.1 down to a Dolby Stereo track. I have used the Neyrinck one and have been pleased with the result.
Randall
Old 07-29-2009, 01:39 PM
Thanks for the info. I'll check into some other plugs.
HTML code is On
perfect mid/side encode/decode in PT? James Drake Pro Tools TDM Systems (Mac) 21 09-25-2011 12:11 AM
Waves Surround for 5.1 encode to LTRT? Johnny2Laps Post - Surround - Video 16 07-11-2009 05:54 AM
SRS Circle Surround EarHole Post - Surround - Video 17 03-20-2009 10:52 AM
Monitoring 6 ch's @96Khz Encode/Decode DarthFader777 Post - Surround - Video 7 01-30-2008 08:36 PM
SRS Circle Surround - Matrix Surround Troubles mrdale Post - Surround - Video 1 08-11-2006 02:12 PM
