Old 03-26-2022, 10:01 AM
Lucas006254 Lucas006254 is offline
Default Problem protools & soundcard
I have a PC under Windows 10, a UR22C steinberg soundcard and when I open protools, no other application can play any sound.
Would you have a idea to solve this problem ?
Thank you
Old 03-26-2022, 01:33 PM
Default Re: Problem protools & soundcard
Originally Posted by Lucas006254 View Post
Thank you
Use the builtin soundcard to play Windows sounds. ProTools wants to be the sole user of a soundcard in Windows.
Jack
QAPLA!
Old 03-26-2022, 01:39 PM
Thanks for your answer
Old 03-26-2022, 05:38 PM
This is due to the interface driver not being "multi-client" and this solution is pretty standard for all Windows systems. If you are now wondering how you can hear non-PT sound while PT is using the interface, there are a couple of solutions:
1-use a monitor/source selector(like Audient Nero or Presonus Monitor Station, for example). Not the cheap solution, but probably the best solution.
2-grab a small mixer(think Behringer, Alto, Alesis, etc) that has 2 stereo line inputs. Feed 1 set from the interface outputs. Feed the other set from the on-board sound card(mini-TRS to dual mono quarter inch plugs). Connect the mixer outputs to your speakers and balance the 2 sources with the mixer volume knobs. This solution might cost less than $40-50.
Old 03-27-2022, 01:56 AM
Merci
Problem: ZOOM H6 as soundcard to ProTools 10 johanmusik Pro Tools 10 3 06-12-2014 10:07 PM
ProTools 9 with NO soundcard... fabs6 macOS 3 06-01-2011 02:11 PM
Problem with Vista's soundcard stump 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-17-2009 08:14 AM
do i need a soundcard to run protools sethbrand 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-12-2005 11:51 AM
Best Soundcard(MAC) for Cubase& ProTools Moses Saxon Pro Tools TDM Systems (Mac) 0 07-05-2000 01:48 PM
