ReWire Reason 4 & ProTools LE 8 Tempo Not Right
Im having a little problem that I can't figure out how to fix. I am using both Reason 4 & ProTools LE 8, the problem that I am running into is the tempo. I create a drum with Reason using ReDrum, then I ReWire it into ProTools, I set the tempo at 96, so both Reason and ProTools are at a tempo of 96, so I ReWire the drum into ProTools and I set it up as an audio track to record the drum I made with ReDrum into ProTools, now I click on the run button in ReDrum and the tempo everything sounds fine, but when I starting recording the drum into ProTools the drum sounds like it's at a tempo of 20, real slow, but I looked again at both tempos both ProTools and Reason and there both set at 96. Does anyone know how to fix this? It didn't do this before and I don't know what happened.
Thanks |
Re: ReWire Reason 4 & ProTools LE 8 Tempo Not Right
Pro Tools has a half-speed recording feature - if you hold down shift when you press ctrl-spacebar to record. Make sure you are not doing that accidentally...
There's another possible solution I can think of. In Reason, go to edit>change events, check if there is scale tempo... I think it might be that, because you said the sound from reason appears slower. Hope you will fix it
No I'm still having the same problem, I go into ProTools LE 8 I click insert, multichannel plug-in, Instrument, then Reason 4. I load Reason 4 then ReDrum. I create a drum loop with ReDrum, after I click the run button in ReDrum, tempo's fine, I ereate a new stereo audio track and set it's input to 1-2 Bus, then I set the output of the instrument track's output which is Reason to 1-2 Bus. I set record enable and I start recording the drum into ProTools as an audio track, but as it's recording the tempo of the drum is very slow.
When you hit the preview button in Redrum, are you sure it is playing back at the right tempo? What happens in ProTools when you play the session, but don't record? Does it still play in the wrong tempo?
I would suggest starting a new Reason file, but not changing the tempo in Reason from the default. Instead, only set your tempo in Protools. Does that solve the issue? When you say it plays back slowly, does it still play back in the correct pitch, or is it playing back at a lower pitch? How about after you record, when you then play back the session? |
When I play click the run button in Redrum the tempo is for sure correct. When I play the Drum through ProTools without record I can't hear the drum without recording it into ProTools first, however, when I try to play the drum in ProTools without record I can't hear it but I can see activity through the mixer and it looks like the color on the mixer doesn't move up or down correctly, it movies up and down slow as if the tempo is slow. I always start protools first and adjusting the tempo in protools, still having problems, when it plays back slowly is stays in the correct pitch. When I record the drum into ProTools the drum playsback slow but stays at the correct pitch.
when hitting play in reason it is playing it at the internal tempo of reason, when your recording through pro tools it is now slaving to pro tools. you need to set the tempo in pro tools to what you would like it to be (the same as reason). this would be my guess. check out the tempo editor or set it manually. these would be the easiest, though many ways to do it.
pro-tools-pc.com TRASHER Pro Tools Utility(updated 3-6-18) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
Yes, when I hit the play button in Reason it is playing at the internal tempo of Reason. It has always been slaving into ProTools LE 8. I have always been setting the tempo in Protools to what I liked it to be the same as Reason. I never had this problem before, before I did this everything worked fine. I can't figure out whats going on.
I just notice something when I click the play button in ProTools the tempo isn't correct. I set the tempo at 96 in ProTools and it's playing at I don't know sounds life 20 maybe 30.
strange Reason/Pro Tools rewire tempo issue | scullionj | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-26-2010 05:53 AM |
Reason ReWire IN ProTools LE | crazyjazzdrummer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 10-30-2009 12:54 PM |
Reason Rewire with mac and Protools | teketuco | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 11-16-2008 08:58 AM |
protools 6.9 +rewire in reason | steveurwin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-25-2005 09:08 PM |
Reason/Rewire/Pt's tempo stuck @ 120?? | Tim R. | Pro Tools TDM Systems (Mac) | 3 | 09-30-2003 09:02 PM |
