Old 09-03-2015, 09:31 AM
marcodeangelis marcodeangelis is offline
Default Single license for two platform.
Hi guys I'm an old user since PT 4.1 TDM
Now I have two different warkstation, a more than old system on mac and a less old but not last release pro tools MP9 on Win.
I'd like to upgate my MP9 to PT12 (software only) and wondering if will be possible to install the software on my PC Win7 and a new Mac Mini i7 quad core Yosemite, using them alternatively just moving the Ilok.
Any help would be appreciate.
Thanks in advance
Marco
SiSoftware Sandra
ID
Nome Host : Marco-HP
Workgroup : WORKGROUP
Sistema
Modello : HP Pro 3015 Microtower PC 103C_53307F
Numero Seriale : CZC94*****
Chassis : HP Desktop
Mainboard : Pegatron 2A9Eh
Numero Seriale : 1018882********
BIOS Sistema : AMI (OEM) 5.11 11/02/2009
Memoria Totale : 3.44GB DIMM DDR3
Processore
Processore : AMD Athlon(tm) II X2 215 Processor (2C 2.7GHz, 2GHz IMC, 512kB L2)
Socket/Slot : AM2r2/AM3
Chipset
Controller di Memoria : AMD F10 Athlon 64/Opteron/Sempron HT Hub 2x 2GHz (4GHz), 4GB DIMM DDR3 1GHz 64-bit
Moduli di Memoria
Modulo di Memoria : Samsung M378B5773SB0-CK0 2GB DIMM DDR3 PC3-12800U DDR3-1600 (11-11-11-29 5-40-13-6)
Sistema Video
Monitor : ACI ASUS VH222
(1920x1080, 21.1")
Adattatore Video : NVIDIA GeForce 9100 (1CU 16SP SM4.0 1.2GHz, 64MB DDR2 1GHz 128-bit, Grafica Integrata)
Processore Grafico
Processore OpenCL : NVIDIA GeForce 9100 (8SP 1C 1.2GHz, 64MB DDR2 1GHz 128-bit, Grafica Integrata)
Processore di Calcolo Shader : NVIDIA GeForce 9100 (16SP 1C 1.2GHz, 64MB DDR2 1GHz 128-bit, Grafica Integrata)
Unità di Memorizzazione Fisiche
Seagate ST3250318AS (250GB, SATA300, 3.5", 7200rpm, 8MB Cache) : 233GB (C:) (D:)
PIONEER DVD-RW DVR-220L (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (E:)
Unità di Memorizzazione Logiche
SYSTEM : 1023MB (NTFS, 4kB) @ Seagate ST3250318AS (250GB, SATA300, 3.5", 7200rpm, 8MB Cache)
OS (C:) : 229GB (NTFS, 4kB) @ Seagate ST3250318AS (250GB, SATA300, 3.5", 7200rpm, 8MB Cache)
HP_RECOVERY (D:) : 3GB (NTFS, 4kB) @ Seagate ST3250318AS (250GB, SATA300, 3.5", 7200rpm, 8MB Cache)
CD-ROM/DVD (E:) : N/A @ PIONEER DVD-RW DVR-220L (SATA150, DVD+-RW, CD-RW, 2MB Cache)
Periferiche
Controller LPC Hub 1 : HP Pavilion p6310f
Periferica Audio : VIA M-Audio Delta AP192
Controller Disco : HP Pavilion p6310f
Controller USB 1 : HP Pavilion p6310f
Controller USB 2 : HP Pavilion p6310f
Controller USB 3 : HP Pavilion p6310f
Controller USB 4 : HP Pavilion p6310f
Controller FireWire/1394 1 : HP Pavilion p6310f
Controller di Sistema SMBus 1 : nVidia MCP5 SMBus 1
Controller di Sistema SMBus 2 : nVidia MCP5 SMBus 2
Stampanti e Fax
Stampante : PDF24 (4000x4000, Gestione colori immagine)
Stampante : Microsoft XPS Document Writer (600x600, Gestione colori immagine)
Servizi di Networking
Adattatori di Rete : NVIDIA nForce 10/100 Mbps Ethernet (Ethernet, 100Mbps)
Sistema Operativo
Sistema Windows : Microsoft Windows 7 Ultimate Media Center 6.01.7601 Service Pack 1
Conformità della piattaforma : x86
Old 09-03-2015, 10:18 AM
mesaone mesaone is offline
Default Re: Single license for two platform.
You absolutely can do that. That's one of the few benefits of iLok.
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix
Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB
Old 09-03-2015, 10:34 AM
sw rec sw rec is offline
Just looking at your Sandra report, though (thanks for providing that!) and I'm thinking that PT12 won't even INSTALL on that rig. Nowhere near enough ram, no secondary hard drive, and an AMD processor. But hey, it's worth a try! They said PT 8.0.5 wouldn't run on Win 8.1, and it works quite nicely.
Old 09-03-2015, 10:36 AM
JoelG's Avatar
JoelG JoelG is online now
As Measone mentioned, yes you can move between computers. However, you should check the system requirements first, as your posted system is outside of the recommended hardware:http://avid.force.com/pkb/articles/e...m-Requirements
Joel
Jam Space:
HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro
Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro
Rig:
Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM
Old 09-04-2015, 03:45 AM
Thank mesaone.
I assume by your answer that the installer I'd download will work either for win or mac. Is it right?
Cheers
Old 09-04-2015, 03:55 AM
Hi sw rec thanks for your reply.
You are right.... the fact is that I posted the sandra report I made with the 32 bit startup disk and with all the external drives (laciè d2 quadra) turned off. My fault. I could switch my win system to a 64bit win 7 professional which will allow me to fully use up to 16GB ram.
On the processor side... well, probably you are right....I just need to check it out on the avid compatibility list.
On the mac side, I think that my mac mini quad core i7 16 GB ram could be good enough to run PT12 without too much active plugins... I don't need to mix in the box, just to play a medium number of audio tracks.
Old 09-04-2015, 03:58 AM
Hi JoelG, thanks.
I'll do it. I have the possibility to use a little bit more powered system under win - I explained that in my replay to Sw Rec.
Cheers
Multiple iLoks, Single PT License DelawareAve95 Getting Started 5 04-12-2014 03:00 PM
Can not download Pro Tools 11 license to my iLok2 -incomplete license surrender issue StereoZzilla Pro Tools 11 10 01-04-2014 11:11 PM
ilok - Cannot download license: Pro Tools 10+9 Bundle requires surrender of license soukotta Pro Tools 10 10 09-25-2012 07:22 AM
The enclosed license card allows a single installation? joerusi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 11-23-2009 11:26 AM
Single Pultec EQH-2 license wont work with the bundle download carl_laruso Pro Tools TDM Systems (Mac) 1 03-09-2009 09:31 AM
