Old 01-21-2008, 12:56 PM
krysbaxter krysbaxter is offline
Default access violation on opening application
i am having problems opening up pro tools. i have just upgraded to 7.4 on vista home premium 32bit. every time i try to open up it gets halfway then freezes with error box stating access violation has occurred. please can anyone help me fix this problem as it driving me mad. i have downloaded and installed the cs2 fix but to no results.
cheers krys
Old 01-21-2008, 01:06 PM
spkguitar's Avatar
Default Re: access violation on opening application
Access violations can be caused by quite a number of different issues, including but not limited to, out of date plugins, using illegal ("cracked") versions of plugins, compressed files on the hard drive, hard drive errors, unsupported hardware, etc.
So, some quick things to check;
  1. Make sure all of your plugins are up to date, valid versions
  2. make sure you are using the latest version of the PACE driver from www.paceap.com
  3. check your hard drive for errors
  4. Check to make sure the drive is not full
  5. Check to make sure that the drive and/or it's folders has not been compressed (running the Windows "Disk Cleanup" on a drive can cause this)
If you could please post a plugin list using the utility in the Tech Support Folder, That will allow us to identify any plugins that you have that may be causing this problem due to being out of date or unsupported.
It would also be extremely helpful if you posted details about your system as directed in the General Troubleshooting post above.
Old 01-21-2008, 01:16 PM
thanks for the help dude ill start removing plug ins to see if it works after that. sorry about the details.
Access Violation when opening sessions PLAbass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-12-2007 02:31 PM
Access violation occured when opening movie files discostu131 Pro Tools M-Powered (Win) 1 10-20-2006 11:56 PM
"Access violation occurred" when opening a session PLAbass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 10-06-2006 09:08 PM
Access Violation when opening and using video... Dazrae 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 08-18-2005 11:27 AM
Access Violation prevents song file from opening sophiahat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-28-2004 12:56 AM
