whats the key? i have nightmares compressing the mixes (only about 2db of reduction) then pushing the make up gain which in turn pushes the threshold further. i just feel like im going around in circled sometimes. also what compressors do you guys suggest? i have MCdsp, URS, Waves, Slightly rude, smack and t-racks software ive also got a dramwer 1960 i could try as outboard? any suggestions would be great
![]() Quote:
not sure i understand. The make up gain shouldnt be affecting the threshold at all. There shouldnt be any feedback from the make up gain back to the input? Can ya clarify ol bean? |
yeah on the master channel input and output are related
while putting a compressor on the master buss is not a good thing to do if you are sending away for mastering, it can be usefull for client mixes. you need a compressor that is designed for the master buss. i have been using the massey L2007 with success...
the Massey is a limiter
skwad, Are you talking about mastering? If you're talking about the mix my advice is to clear the master fader. I rarely have anything on it. For mastering Flux Solera beats the crap out of the competition as far as plug-ins go. Hardware might be another story though, I don't really have enough experience with that. |
![]() Quote:
I used the standard chain on the master fader EQ/Comp/Limiter/Dither - some tracks I used T-RAcks mastering Suite and others (where I had enough CPU Juice) I used seperate plug-ins (waves/Massey) with great results also. I recently got hold of Flux Solera too and my prelim tests with this one have impressed me greatly. ....but the caveat I should add is I will always (and I recommend you do too) go to a prof Mastering engineer for the final stage of a recording. Do a search on the DUC on mastering too - you will turn up heaps of stuff. Good luck.
002R, PTLE 7.3, P'book G4, 1.5Ghz, OSX 10.4, 1 Gig Ram |
![]() Quote:
I'm using a very old Tascam 4 track desk that has 4 VU meters (1 per channel but I only use two of them) - it's one where the actual tape machine was seperate. I'm getting a proper set made up in a nice wooden box but in the meantime this works a treat - I couldn't live without them now.
If you can't get your hands on VU meters then check out PSP cos they have a VU Meter plug in that works pretty good. I checked it against my analogue VU and they were very close. http://www.pspaudioware.com/
uuhh, pt le comes with the bomb factory essential meter....
...which is pretty crap, sorry if that's blunt but it is...crap that is!!
Compression on Master for tv series | zzstation | Post - Surround - Video | 14 | 10-07-2011 02:46 AM |
Newbie Question re: Master Compression | John Barnes | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-17-2008 03:24 PM |
Which plugin for Master Bus Compression ? | seth666 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-03-2006 09:19 PM |
Master Track Compression | eldangeroso | General Discussion | 8 | 06-24-2004 06:45 AM |
master compression | ttyner | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 12-06-2000 04:39 AM |
