How to LOCK a Track Height?
Is there a way to Lock a track's Height in the Edit Window??
Although, I am still at PT 7.3.1...I know this feature does not exists....but maybe this has been implemented in PT 8.x. Thanks, |
Re: How to LOCK a Track Height?
well, one way to do this is to save your trk heights
as part of a mem/locate position, then if things change you get 'em back with a quick key command. b.o.l. e e.p.s. btw, this is available now on your v7...
ihatetyping |
What I'm actually wanting to do is.....minimize and Lock all AUX track's height so that they will not Resize when I Resize ALL <Option> audio Tracks.
My thought here is that...When Resizing ALL tracks using the <option> shortcut, there should be some way to filter out or only choose which type of tracks you want to resize. I don't particularly care to resize AUX tracks due to they don't show anything more than just an automation data-line; thus taking up more Screen Space in the Edit Widow. Otherwise, maybe there should be a preference or shortcut to: 1) Resize ALL Tracks 2) Resize Audio Tracks Only 3) Resize MIDI Tracks Only 4) Resize Instrument Tracks Only OH, BTW....speaking of Resizing Tracks....what about individually Resizing Channel Strips in the Mix Window?? Later, |
My kludge is to make a group(s) of the tracks you want to resize, select the group and then shift option resize to change the height of the highlighted tracks.
E.
Neotech Concepts http://www.imdb.com/name/nm0235036/ ! sonic gymnastics for the illusionary arts ! 2022 Mac Studio Max 64GB / 1TB, macOSX 13.6.6, 2019 i9 MacBook Pro (15,3), macOSX 14.4.1, PT Ulti 2024.3.0, DAR 5.1, MDA Creator1.5, Rx10 Advanced, Ozone 10 Advanced, Kontakt 7, Soundminer v6.1Pro, Spanner 4, PaulXStretch, EuControl 2023.11.0, Avid Control 2023.11.0, Avid S1, iPad Pros 12.9" gen 3 & gen 4, Apollo 8 Duo, UAD-2 Satellite Quad, Glyph 2TB tb3 NVMe SSD, x2 Glyph 2TB SSDs, x1 Glyph 4TB SSD, OWC tb3 Dock, OWC Thunderbay 8 62TB |
track height | jknourse | Windows | 1 | 07-18-2012 02:06 PM |
Track height problems in PT 7.1 | fuzzles | Pro Tools TDM Systems (Mac) | 8 | 09-20-2008 11:34 AM |
track height woes | jon Oh | Pro Tools TDM Systems (Mac) | 4 | 04-26-2007 10:47 AM |
Group Track Height won go away!!!! | mstucker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-08-2007 02:46 PM |
Track height problem with 7.3 | 4string | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-06-2007 07:43 AM |
