Pro Tools don't start
Please can anybody help me? I press the pro tools icon and automatically tells me Pro tools quit unexpectedly. I uninstalled pro tools, Installed it again, repaired the permissions and nothing. I don't know what else to do.
Can anyone help me please? |
Re: Pro Tools don't start
is your ilok connected?
Yes it's connected.
W/o the ilok it says authorize and when i put it again an launch PT it says the same thing
is the PT license on the ilok? Is there a problem with the ilok USB port? Go into ilok.com and see if it sees the ilok and if the license is there
In ilok.com I see all my plugins but in the type column it says backup. I dont know if it has to say license like the other ones.
Thank you so much for your help
Little help anyone?
This is the report of the issue
Date/Time: 2012-01-04 14:47:53.526 -0500 OS Version: 10.4.11 (Build 8S165) Report Version: 4 Command: Pro Tools HD Path: /Applications/Digidesign/Pro Tools/Pro Tools HD.app/Contents/MacOS/Pro Tools HD Parent: WindowServer [118] Version: 7.4 (7.4f309) PID: 419 Thread: 0 Exception: EXC_BAD_ACCESS (0x0001) Codes: KERN_PROTECTION_FAILURE (0x0002) at 0x00000006 Thread 0 Crashed: 0 com.apple.CoreFoundation 0x907bebd8 CFRelease + 92 1 ...gn.framework.CoreFoundation 0x0252c2c0 I18N_Utils::GetCurrentLanguage() + 2048 2 com.digidesign.ProToolsHD 0x00ff3660 start + 16715168 3 com.digidesign.ProToolsHD 0x00002bec start + 812 4 com.digidesign.ProToolsHD 0x000028f0 start + 48 Thread 1: 0 libSystem.B.dylib 0x90053f88 semaphore_timedwait_signal_trap + 8 1 libSystem.B.dylib 0x900707e8 pthread_cond_timedwait_relative_np + 556 2 ...ple.CoreServices.CarbonCore 0x90bf9330 TSWaitOnSemaphoreCommon + 176 3 ...ple.CoreServices.CarbonCore 0x90c012d0 TimerThread + 60 4 libSystem.B.dylib 0x9002b908 _pthread_body + 96 Thread 2: 0 libSystem.B.dylib 0x90053f88 semaphore_timedwait_signal_trap + 8 1 libSystem.B.dylib 0x900707e8 pthread_cond_timedwait_relative_np + 556 2 ...ple.CoreServices.CarbonCore 0x90bf9330 TSWaitOnSemaphoreCommon + 176 3 ...ple.CoreServices.CarbonCore 0x90c04e04 DeferredTaskThread + 56 4 libSystem.B.dylib 0x9002b908 _pthread_body + 96 Thread 0 crashed with PPC Thread State 64: srr0: 0x00000000907bebd8 srr1: 0x100000000000f030 vrsave: 0x0000000000000000 cr: 0x22000422 xer: 0x0000000000000000 lr: 0x00000000907beb84 ctr: 0x00000000907beb7c r0: 0x000000000252c2c0 r1: 0x00000000bffff7a0 r2: 0x00000000a07beb84 r3: 0x0000000000000000 r4: 0x0000000000000000 r5: 0x00000000a07bbb90 r6: 0x0000000004060401 r7: 0x0000000001030301 r8: 0x0000000068363567 r9: 0x00f8dfa32af67397 r10: 0x00f8dfa1ca3b8382 r11: 0x00000000026369e8 r12: 0x0000000000000000 r13: 0x0000000000000000 r14: 0x0000000000000000 r15: 0x0000000000000000 r16: 0x0000000000000000 r17: 0x0000000000000000 r18: 0x0000000000000000 r19: 0x0000000000000000 r20: 0x0000000000000000 r21: 0x000000000266bacc r22: 0x0000000000000000 r23: 0x0000000000000000 r24: 0x0000000000000000 r25: 0x0000000001ff363c r26: 0x00000000bffffd04 r27: 0x00000000bffffce8 r28: 0x00000000bffffcdc r29: 0x0000000000000000 r30: 0x000000000000006e r31: 0x00000000907beb84 Binary Images Description: 0x1000 - 0x17c5fff com.digidesign.ProToolsHD 7.4 (7.4f309) /Applications/Digidesign/Pro Tools/Pro Tools HD.app/Contents/MacOS/Pro Tools HD 0x23b0000 - 0x23dafff com.digidesign.framework.CFD 7.4 (7.4f309) /Applications/Digidesign/Pro Tools/Pro Tools HD.app/Contents/Frameworks/CFD.framework/Versions/A/CFD 0x23ee000 - 0x23f1fff libFicClockComponent.dylib /Applications/Digidesign/Pro Tools/Pro Tools HD.app/Contents/Frameworks/libFicClockComponent.dylib 0x2505000 - 0x2635fff com.digidesign.framework.CoreFoundation 7.4 (7.4f309) /Library/Frameworks/CFnd.framework/Versions/A/CFnd 0x26d3000 - 0x26e7fff com.digidesign.framework.DMC 7.4 (7.4f309) /Applications/Digidesign/Pro Tools/Pro Tools HD.app/Contents/Frameworks/DMC.framework/Versions/A/DMC 0x26f7000 - 0x277bfff com.digidesign.framework.DSI 7.4 (7.4f309) /Library/Frameworks/DSI.framework/Versions/A/DSI 0x3008000 - 0x31f2fff com.digidesign.framework.DFW 7.4 (7.4f309) /Applications/Digidesign/Pro Tools/Pro Tools HD.app/Contents/Frameworks/DFW.framework/Versions/A/DFW 0x3312000 - 0x37c1fff com.digidesign.framework.FileFormat 7.4 (7.4f309) /Applications/Digidesign/Pro Tools/Pro Tools HD.app/Contents/Frameworks/FFmt.framework/Versions/A/FFmt 0x3be8000 - 0x3f6afff com.digidesign.framework.DAE 7.4 (7.4f309) /Library/Frameworks/DAE.framework/Versions/A/DAE 0x4280000 - 0x4439fff com.digidesign.framework.DHS 7.4 (7.4f309) /Library/Frameworks/DHS.framework/Versions/A/DHS 0x44a1000 - 0x44d3fff com.digidesign.framework.PlatformSupport 7.4 (7.4f309) /Library/Frameworks/DigiPlatformSupport.framework/Versions/A/DigiPlatformSupport 0x44f0000 - 0x4514fff com.digidesign.framework.SystemLink 7.4 (7.4f309) /Applications/Digidesign/Pro Tools/Pro Tools HD.app/Contents/Frameworks/SystemLink.framework/Versions/A/SystemLink 0x4754000 - 0x4842fff libxml2.2.dylib /usr/lib/libxml2.2.dylib 0x486f000 - 0x4bccfff libNeoAccessPro.dylib /Applications/Digidesign/Pro Tools/Pro Tools HD.app/Contents/Frameworks/libNeoAccessPro.dylib 0x4ccb000 - 0x4da6fff libOMFToolkit.dylib /Applications/Digidesign/Pro Tools/Pro Tools HD.app/Contents/Frameworks/libOMFToolkit.dylib 0x4dbd000 - 0x4e27fff com.digidesign.framework.DUI 7.4 (7.4f309) /Library/Frameworks/DUI.framework/Versions/A/DUI 0x4e43000 - 0x4eb8fff com.digidesign.framework.DSPManager 7.4 (7.4f309) /Library/Frameworks/DSPManager.framework/Versions/A/DSPManager 0x5b50000 - 0x5bb8fff com.DivXInc.DivXDecoder 6.4.0 /Library/QuickTime/DivX Decoder.component/Contents/MacOS/DivX Decoder 0x6d6c000 - 0x6d93fff DigiMachOServices 7.4 (7.4f309) /Library/Frameworks/DigiMachOServices.framework/DigiMachOServices 0x192f2000 - 0x19301fff com.apple.iokit.IOUSBLib 2.8.1 /System/Library/Extensions/IOUSBFamily.kext/Contents/PlugIns/IOUSBLib.bundle/Contents/MacOS/IOUSBLib 0x8fe00000 - 0x8fe52fff dyld 46.16 /usr/lib/dyld 0x90000000 - 0x901bcfff libSystem.B.dylib /usr/lib/libSystem.B.dylib 0x90214000 - 0x90219fff libmathCommon.A.dylib /usr/lib/system/libmathCommon.A.dylib 0x9021b000 - 0x90268fff com.apple.CoreText 1.0.4 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText 0x90293000 - 0x90344fff ATS /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS 0x90373000 - 0x9072efff com.apple.CoreGraphics 1.258.85 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics 0x907bb000 - 0x90895fff com.apple.CoreFoundation 6.4.11 (368.35) /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation 0x908de000 - 0x908defff com.apple.CoreServices 10.4 (???) /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices 0x908e0000 - 0x909e2fff libicucore.A.dylib /usr/lib/libicucore.A.dylib 0x90a3c000 - 0x90ac0fff libobjc.A.dylib /usr/lib/libobjc.A.dylib 0x90aea000 - 0x90b5cfff com.apple.framework.IOKit 1.4 (???) /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit 0x90b72000 - 0x90b84fff libauto.dylib /usr/lib/libauto.dylib 0x90b8b000 - 0x90e62fff com.apple.CoreServices.CarbonCore 681.19 (681.21) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore 0x90ec8000 - 0x90f48fff com.apple.CoreServices.OSServices 4.1 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices 0x90f92000 - 0x90fd4fff com.apple.CFNetwork 4.0 (129.24) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork 0x90fe9000 - 0x91001fff com.apple.WebServices 1.1.2 (1.1.0) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/WebServicesCore.framework/Versions/A/WebServicesCore 0x91011000 - 0x91092fff com.apple.SearchKit 1.0.8 /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit 0x910d8000 - 0x91101fff com.apple.Metadata 10.4.4 (121.36) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata 0x91112000 - 0x91120fff libz.1.dylib /usr/lib/libz.1.dylib 0x91123000 - 0x912defff com.apple.security 4.6 (29770) /System/Library/Frameworks/Security.framework/Versions/A/Security 0x913dd000 - 0x913e6fff com.apple.DiskArbitration 2.1.2 /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration 0x913ed000 - 0x913f5fff libbsm.dylib /usr/lib/libbsm.dylib 0x913f9000 - 0x91421fff com.apple.SystemConfiguration 1.8.3 /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration 0x91434000 - 0x9143ffff libgcc_s.1.dylib /usr/lib/libgcc_s.1.dylib 0x91444000 - 0x914bffff com.apple.audio.CoreAudio 3.0.5 /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio 0x914fc000 - 0x914fcfff com.apple.ApplicationServices 10.4 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices 0x914fe000 - 0x91536fff com.apple.AE 312.2 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE 0x91551000 - 0x91623fff com.apple.ColorSync 4.4.13 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync 0x91676000 - 0x91707fff com.apple.print.framework.PrintCore 4.6 (177.13) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore 0x9174e000 - 0x91805fff com.apple.QD 3.10.28 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD 0x91842000 - 0x918a0fff com.apple.HIServices 1.5.3 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices 0x918cf000 - 0x918f0fff com.apple.LangAnalysis 1.6.1 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis 0x91904000 - 0x91929fff com.apple.FindByContent 1.5 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/FindByContent.framework/Versions/A/FindByContent 0x9193c000 - 0x9197efff com.apple.LaunchServices 183.1 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices 0x9199a000 - 0x919aefff com.apple.speech.synthesis.framework 3.3 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis 0x919bc000 - 0x91a02fff com.apple.ImageIO.framework 1.5.9 /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO 0x91a19000 - 0x91ae0fff libcrypto.0.9.7.dylib /usr/lib/libcrypto.0.9.7.dylib 0x91b2e000 - 0x91b43fff libcups.2.dylib /usr/lib/libcups.2.dylib 0x91b48000 - 0x91b66fff libJPEG.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib 0x91b6c000 - 0x91c23fff libJP2.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib 0x91c72000 - 0x91c76fff libGIF.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib 0x91c78000 - 0x91ce2fff libRaw.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRaw.dylib 0x91ce7000 - 0x91d02fff libPng.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib 0x91d07000 - 0x91d0afff libRadiance.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib 0x91e19000 - 0x91e57fff libTIFF.dylib /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib 0x91e5e000 - 0x91e5efff com.apple.Accelerate 1.2.2 (Accelerate 1.2.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate 0x91e60000 - 0x91f45fff com.apple.vImage 2.4 /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage 0x91f4d000 - 0x91f6cfff com.apple.Accelerate.vecLib 3.2.2 (vecLib 3.2.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib 0x91fd8000 - 0x92046fff libvMisc.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib 0x92051000 - 0x920e6fff libvDSP.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib 0x92100000 - 0x92688fff libBLAS.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib 0x926bb000 - 0x929e6fff libLAPACK.dylib /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib 0x92a16000 - 0x92b04fff libiconv.2.dylib /usr/lib/libiconv.2.dylib 0x92b07000 - 0x92b8ffff com.apple.DesktopServices 1.3.7 /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv 0x92bd0000 - 0x92e03fff com.apple.Foundation 6.4.12 (567.42) /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation 0x92f36000 - 0x92f54fff libGL.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib 0x92f5f000 - 0x92fb9fff libGLU.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib 0x92fd7000 - 0x92fd7fff com.apple.Carbon 10.4 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon 0x92fd9000 - 0x92fedfff com.apple.ImageCapture 3.0 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture 0x93005000 - 0x93015fff com.apple.speech.recognition.framework 3.4 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition 0x93021000 - 0x93036fff com.apple.securityhi 2.0 (203) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI 0x93048000 - 0x930cffff com.apple.ink.framework 101.2 (69) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink 0x930e3000 - 0x930eefff com.apple.help 1.0.3 (32) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help 0x930f8000 - 0x93126fff com.apple.openscripting 1.2.7 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting 0x93140000 - 0x9314ffff com.apple.print.framework.Print 5.2 (192.4) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print 0x9315b000 - 0x931c1fff com.apple.htmlrendering 1.1.2 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering 0x931f2000 - 0x93241fff com.apple.NavigationServices 3.4.4 (3.4.3) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices 0x9326f000 - 0x9328cfff com.apple.audio.SoundManager 3.9 /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound 0x9329e000 - 0x932abfff com.apple.CommonPanels 1.2.2 (73) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels 0x932b4000 - 0x935c2fff com.apple.HIToolbox 1.4.10 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox 0x93712000 - 0x9371efff com.apple.opengl 1.4.7 /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL 0x93798000 - 0x93dcbfff com.apple.AppKit 6.4.10 (824.48) /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit 0x94158000 - 0x941cafff com.apple.CoreData 91 (92.1) /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData 0x94203000 - 0x942c8fff com.apple.audio.toolbox.AudioToolbox 1.4.7 /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox 0x9431b000 - 0x9431bfff com.apple.audio.units.AudioUnit 1.4 /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit 0x9431d000 - 0x944ddfff com.apple.QuartzCore 1.4.12 /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore 0x94527000 - 0x94564fff libsqlite3.0.dylib /usr/lib/libsqlite3.0.dylib 0x9456c000 - 0x945bcfff libGLImage.dylib /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib 0x945c5000 - 0x945defff com.apple.CoreVideo 1.4.2 /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo 0x94816000 - 0x94b49fff com.apple.QuickTime 7.6.4 (1327.73) /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime 0x94c31000 - 0x94ca2fff libstdc++.6.dylib /usr/lib/libstdc++.6.dylib 0x966e4000 - 0x96723fff com.apple.audio.midi.CoreMIDI 1.5 (41) /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI 0x96a0f000 - 0x96a2efff com.apple.vecLib 3.2.2 (vecLib 3.2.2) /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib 0x9728b000 - 0x97298fff com.apple.agl 2.5.6 (AGL-2.5.6) /System/Library/Frameworks/AGL.framework/Versions/A/AGL 0x986e8000 - 0x99321fff com.apple.QuickTimeComponents.component 7.6.4 (1327.73) /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents 0x9aa6c000 - 0x9aaf5fff com.tcltk.tcllibrary 8.4.7 /System/Library/Frameworks/Tcl.framework/Tcl 0x9ff40000 - 0x9ffe2fff com.apple.QuickTimeImporters.component 7.6.4 (1327.73) /System/Library/QuickTime/QuickTimeImporters.component/Contents/MacOS/QuickTimeImporters Model: PowerMac7,2, BootROM 5.1.5f0, 2 processors, PowerPC 970 (2.2), 1.8 GHz, 6 GB Graphics: ATI Radeon 9800 Pro, ATY,R350, AGP, 256 MB Memory Module: DIMM0/J11, 512 MB, DDR SDRAM, PC3200U-30330 Memory Module: DIMM1/J12, 512 MB, DDR SDRAM, PC3200U-30330 Memory Module: DIMM2/J13, 512 MB, DDR SDRAM, PC3200U-30330 Memory Module: DIMM3/J14, 512 MB, DDR SDRAM, PC3200U-30330 Memory Module: DIMM4/J41, 1 GB, DDR SDRAM, PC3200U-30330 Memory Module: DIMM5/J42, 1 GB, DDR SDRAM, PC3200U-30330 Memory Module: DIMM6/J43, 1 GB, DDR SDRAM, PC3200U-30330 Memory Module: DIMM7/J44, 1 GB, DDR SDRAM, PC3200U-30330 AirPort: AirPort Extreme, 405.1 (3.90.34.0.p18) Modem: MicroDash, UCJ, V.92, 1.0F, APPLE VERSION 2.6.6 Network Service: Built-in Ethernet, Ethernet, en0 PCI Card: pci-bridge, pci, SLOT-2 PCI Card: pci11af,eed2, sppci_othermultimedia, 7x4 PCI Card: pci1057,ffff, sppci_othermultimedia, 7x5 PCI Card: pci1057,ffff, sppci_othermultimedia, 7x6 PCI Card: pci1057,ffff, sppci_othermultimedia, 7x7 PCI Card: pci1057,ffff, sppci_othermultimedia, 7x8 PCI Card: pci1057,ffff, sppci_othermultimedia, 7x9 PCI Card: pci1057,ffff, sppci_othermultimedia, 7xa PCI Card: pci1057,ffff, sppci_othermultimedia, 7xb PCI Card: pci1057,ffff, sppci_othermultimedia, 7xc PCI Card: firewire, ieee1394, SLOT-3 PCI Card: pci1106,3038, sppci_usbuniversal, SLOT-4 PCI Card: pci1106,3038, sppci_usbuniversal, SLOT-4 PCI Card: pci1106,3104, SLOT-4 Serial ATA Device: ST3160023AS, 149.05 GB Serial ATA Device: SAMSUNG HD103SJ, 931.51 GB Parallel ATA Device: TSSTcorp CDDVDW SH-S202N, 3.17 GB USB Device: USB Device, Up to 12 Mb/sec, 500 mA USB Device: Keyboard Hub, Apple, Inc., Up to 480 Mb/sec, 500 mA USB Device: Hub, Up to 480 Mb/sec, 100 mA USB Device: iLok, iLok, Up to 1.5 Mb/sec, 500 mA USB Device: iLok, iLok, Up to 1.5 Mb/sec, 500 mA USB Device: Apple Optical USB Mouse, Primax Electronics, Up to 1.5 Mb/sec, 100 mA USB Device: Apple Keyboard, Apple Inc., Up to 1.5 Mb/sec, 100 mA FireWire Device: My Book 1112, WD, Up to 400 Mb/sec FireWire Device: My Book 1112, WD, Unknown |
Lion Pro Tools SE won't start on one account, but start on another | AndrewGalas | Pro Tools SE and Essential (Mac) | 2 | 12-15-2011 11:06 AM |
Pro Tools won't start up? | calicobumps | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 07-26-2010 09:28 AM |
Pro Tools will not start up. Help | khenninger | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 11-12-2007 03:51 PM |
Pro Tools won't start on my Mac | Ralph Baumgardner | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-11-2007 02:24 PM |
Pro Tools 5.1 Session Start—Record Start Interval | Avid | Pro Tools TDM Systems (Mac) | 4 | 04-18-2001 08:27 AM |
